bx 3pt
   / bx 3pt #11
automech- What are you trying to hook up? Can you post pics of your 3pt lowered as far it would go next to the implement you trying to hook up that wouldnt ? I trying to figure out what the deal is here since my implements I have is always there at the right level to hook up with. The only thing is the backblade and it needs to be on block for straight hook up.
On a side note, There were a few posts here that using a pat's quickchange would have a bit more lower reach due to a longer reach that might help for you.
   / bx 3pt #12
mine is adjusted to sit 4+- inches from the ground
give me an e-mail addres and I will snap a pic or two and send them to you
   / bx 3pt
I am putting together a 3pt carryall and I was trying to decide where to put the lower pins so I can get max lift. I got home late the last 2 nights so I haven't been able to try setting the mmm to top yet. I bet that advice was right and I will try it tomorrow when I get home. I need to get some lift on the carryall so I can take it uphill without dragging it like my rear blade does sometimes. I just got a camera so I am going to post some pictures soon I hope.
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
3PT PTO POST HOLE DIGGER (A52708)
3PT PTO POST HOLE...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
(2) FIBERGLASS LADDERS (A58374)
(2) FIBERGLASS...
1994 Chevrolet Silverado Suburban (A57148)
1994 Chevrolet...
