BX Fuse Box Question- Spares
   / BX Fuse Box Question- Spares #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
As there are 2 provisions for spare circuits in the fuse box complete with 15 amp and 20 amp fuses, where can I find the hot wire to make it work. Also, under my seat, there is a red with black stripe wire with a female end connector and a black wire with a male end connector, not connected. What are these? Are they the rear work light circuit?
Thanks all!
   / BX Fuse Box Question- Spares #2
The wires under your seat are there for a rear light or whatever you want to use them for. They are on a separate 20A fuse on my BX1800. I used them to wire in a plug I attached to the rops that I attache my lights to for the Winter.
I use magnetic base lights and take them off for Summer.
I could also use the power for a sprayer if I ever buy one in the future.
I forgot to mention that the red/black stripe is the hot one. The black is ground. At least on mine it is. Also this is turned on and off with the ignition. You will want to add a switch and maybe a relay depending on your application. Also note if you have the stock alternator you shouldn't add more than (2) 55W Halogen lights.
Good luck.
Thanks, that works and I will put the rear facing (2)55 watts on that circuit for the standard rear work light. I have also rigged illuminated toggles on the forward side of the SMV bracket in a weatherproof junction box. I want to run a seperate circuit for the forward facing lights from the 20-amp spare fuse in the stock fuse block. I just need to figure out how to get a keyed, hot wire to the junction box. I was surprised there was not already one there. I hade some steel plates made and I am going to cold weld them to the ROPS and paint them Kubota Grey. I also have the heavy duty alternator on order. It should come from the dealer when the snowblower comes. Has any one ever run a keyed hot wire to the fuse box? /forums/images/graemlins/grin.gif
   / BX Fuse Box Question- Spares #4
I used the ones under the seat for the sprayer and plan to use them for Work lites also as soon as I find lights I like. I found a picture of the swicth box I installed. I put a polarized pigtail on it so I could use the same switch for the sprayer or lights.
BTW
What is "cold weld"?
   / BX Fuse Box Question- Spares #5
Yes. I added both rear and forward facing 55 watt Halogen lights to the ROPS.
I purchased 4 of the same brackets that hold the optional rear work light (K2561-96250; PLATE WORKING LIGHT, brackets were $$$), made my own u-bolts out of 1/4" all thread and mounted the lights on the ROPS.
I then purchased 1/2" slit-convoluted sleeving (the same stuff all the wiring on the tractor is already in) from McMaster Carr supply. I installed three 14 gauge wires in the sleeving, ty-rapped it to the rops and routed the sleeving to the seat area and then under the tractor to the front area somewhere around the oil filter. The sleeving was ty-rapped all along the way to keep it secure. Then routed it through the existing wiring hole in the firewall.
I picked up electric from one of the switched spares on the fuse box. I mounted a marine grade SPDT (single pole double throw) switch on the left side of the tractor console. I also mounted two 20 amp enclosed relays either on one of the support brackets or the firewall (can't remember without looking) and did all of the wiring. The way it is set up with the SPDT switch, I can only turn on the front or rear light at one time. I figured I would only be going in one direction at a time when using the lights. I had the high amp alternator installed when I purchased the tractor.
Bottom line, after the long winded explanation, you can run wiring from the back to the front of the tractor with some effort.
</font><font color="blue" class="small">( I picked up electric from one of the switched spares on the fuse box.)</font>
Therein lies my problem. I have two spare fuses on the fuse block. A 15 and a 20 but they are just held in place by electrical tape as there are no contacts to hold them in place as there is no hot wire present. There are no wires at all to these two spares slots. You imply that your has a "keyed" hot wire already there. What gives? /forums/images/graemlins/confused.gif
</font><font color="blue" class="small">( Bottom line, after the long winded explanation, you can run wiring from the back to the front of the tractor with some effort. )</font>
That's exactly what I am going to do. I want my forward lights fused through the box behind the intake screen and the rears by the factory work light contacts under the seat, but also fused up front. /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( BTW What is "cold weld"? )</font>
Bernie
Cold weld is like an epoxy mix of two sperate components, I guess a glue and a hardner but works very well on metal and dries just as hard. It is great for adding a muffler or exhaust to a small engine when you do not have the proper fitting. I don't know how well it will adhere without the significant amount of heart that runs through an exhaust as that does help it cure. Time will tell (or the first tree limb) if I have to make clamps or find 3" u-bolts with threads starting at 1.5" up the ends. On the plus it dries to a Kubota gray! /forums/images/graemlins/cool.gif
I will post pictures when I get back and finish it.
   / BX Fuse Box Question- Spares #8
Steve:
I finally looked at how I had obtained the power for the lights that I mounted on the ROPS.
It turned out that I ran a power wire directly from the main source of the other switched power, which I believe would be the block mounted to the starter motor.
See photo
   / BX Fuse Box Question- Spares #9
Close up
   / BX Fuse Box Question- Spares #10
I took that wire to one of the two spare fuses at the fuse block.
   / BX Fuse Box Question- Spares #11
I then mounted a SPDT (center off) switch to the dash. This switch will only allow one set of lights to operate at any one time.
   / BX Fuse Box Question- Spares #12
I took the switch leads to two 12 volt, 20 amp relays that I mounted to the firewall next to the battery.
   / BX Fuse Box Question- Spares #13
I ran the wires in the 1/2" slit-convoluted sleeving from the area of the oil filter to the rear of the tractor makeing sure to miss the blades of the hydro cooling fan, coming up behind the seat.
   / BX Fuse Box Question- Spares #14
And then to the four lights mounted on the ROPS.
   / BX Fuse Box Question- Spares #15
I also made a removable mount for something called a "Go Light" that can be mounted to either the BX22 or the RTV.
That thread is in the "ATV and Utility Vehicle" forum if you want to see it.
Vince
Thanks. The hot wire is what I needed to figure out to continue. I am away, however, when I get back, I will paint my brackets, mount them and complete the wiring. I will take some pics. I love your switch. I didn't want to cut into the dash and need both fore and aft lights to work at once as wife will do most of the snow removal, so I have put the dual illuminated toggles in a waterproof box on the front of the SMV emblem behind the seat. I'll get pics as soon as it's done!
   / BX Fuse Box Question- Spares #17
Steve:
Sorry for the confusion. I am afraid that I have developed CRS Sydrome (Can't Remember S***).
At this point, I can't remember what I did yesterday, let alone last spring!
OK, I am not finished but have a couple pics. Here are the brackets I had made after a coat of Kubota gray paint. They will hold fore and aft work lights and will be cold welded to rops.
Here's my switch in a weather proof box. I saw someone else do this, so I do not take credit. I was reluctant to cut in the dash, so...
Here's a better shot of the switches. They are illumunated toggles. I will put a little electric grease in the base of them to keep water out as they are not (and should be) marine grade.
I will post the rest when I get back to it.
Pittsburgh Heavy Duty Solid Steel Auto Ramps (A59230)
Pittsburgh Heavy...
John Deere 6195R (A60462)
John Deere 6195R...
GIYI VB59-59" HYD VIBRATING BUCKET (A60430)
GIYI VB59-59" HYD...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
