BX Grass Catcher
   / BX Grass Catcher #11
Surfran,
Great pictures. I’ll add a few cents of my own. As I mentioned in the “Transporting a BX22” thread I did take some pictures of the chute mechanism and make some comments in the "Describe the grass collection system" thread. My apologies if I duplicate those comments here.
First off, a little background. I grew up running my grandfather’s (later my father’s) Simplicity rig that had a blower that was powered by a belt “PTO” (for lack of a better term) and my great-grandfathers IH Cub Cadet that had a blower powered by a separate gas engine. Both hung off the back of the tractor and blew the leaves into a tow behind trailer. Both trailers articulated like one expects a trailer to, not like the JD things with casters.
When I bought my BX2200 with 54” deck I wanted a system that was powered off the tractor and not a separate engine. 1) I really didn’t like the added noise of another engine. 2) I didn’t want yet another small gas engine to maintain. 3) I’m not going to get a tiller soon and wanted to put that rear PTO to good use! I considered the Trac-Vac, Model 854-BX I believe, a PTO driven blower that fires the leaves into a trailer, and of course the Kubota bagger. My dealer (Russ Ruh at DeKane equipment (www.dekane.com), great person and shop by the way, Russ sells giant Case machines worth as much as my house, and I only go to the shop once or twice a year, yet he knows me by name and always has time to chat with someone who only bought a baby ‘Bota), carries both, but had never sold either one so really couldn’t give me honest input.
I decided to go with the Kubota bagger because I knew it would definitely fit the tractor and takes up considerably less space than having a dedicated grass collecting trailer. I don’t know of anyone on TBN with the Trac-Vac PTO driven rig on their BX.
I picked it up from Russ in the box and put it together myself. Easy assembly as all the difficult stuff is pre-assembled in the gearbox / blower unit. Probably took me two hours, going slow.
I was a little dismayed that you need to take the lift brackets off the 3pt lift arms, but when you think about it, since the mower and the 3pt mechanism use the same lift hydro there really isn’t another way to do it. Wait, before I get flames on that I do recall someone on TBN that built a really slick quick hitch type mechanism for their BX bagger. Getting the thing on is a bear, I wrestled with it a while before I came to the (erroneous) conclusion that something was not sized right. I called Russ and he sent out his head mechanic the next day to have a look see. Tractor newbe that I was, his mechanic explained that 3pt hitch implements are not the micro tolerance machines that I might think they are. They often take a mallet whack, drift pin, and foul language to get on. Using all three, he and I were able to wrestle the thing on.
Now that I have practice and know what to expect it is decidedly much easier, although I do use my floor jack to hoist the thing up while I get the top link in place. That’s right, you don’t use the top link itself, instead the bagger has its own “top link” built in that you wrestle into the top link bracket. My apologies to 3pt nomenclature “purists”, after three years of TBN benefiting from the experience of tractor masters, I fear I am still a newbe, so I’m calling the 3pt parts what I THINK they are called, not necessarily WHAT they are called. It probably takes me 10 minutes to put on and 5 to take off. Most of that time is spent removing and attaching the 3pt lift brackets. Kubota does give you some “key ring” pin restrainers to replace the cotters in the pins that have them so this task is not really that difficult.
So, on to the review, those of you who read Fine Homebuilding probably knew to skip to this part and avoid my ranting…
What I like:
1) It is fairly compact and stores very nicely. Those little stand arms that drop down are brilliant.
2) Short 8” take up hose. The Simplicity and Cub rigs I trained on had long 6” take up hoses. I’ve only clogged the thing a couple of times, doing things that I really knew better than to do.
3) Well built. It’s heavy for a reason. Although I hope those bags last.
4) It really works well and sucks up anything. Have some extra shear pins on hand if you do like I did and take it places you know better than to.
5) It is pretty easy (and quick) to empty (see caveat below).
6) It makes a cool jet engine like noise when you flip it on and crank up the throttle!
What I don’t like:
1) It fills up fast. If you’ve got a pile, those three bags don’t seem to go very far.
2) You have to dismount to empty the thing. Although it is pretty simple to pop and dump the three bags, I recall seeing a JD rig that has a hydro dump to it. Maybe a BX22-er with that rear hydro and welder can craft a solution to this. It’ll give me an excuse to put a rear hydro on my 2200.
3) I hope those bags last…
The don’t likes being said, in the two years (yep, the first year I hand raked!) I have had it, my rake has not come off my garage wall…
End of rant…
-- Rock
   / BX Grass Catcher #12
rogue,
Direct answers to your questions. I'll try to hold off on the rant this time.
> Is the bagger easy to take off (I take it you set it on its own stands).
Pretty much like any 3pt implement. As I mentioned in my rant my floor jack comes in real handy.
> Does it go up and down when the deck goes up and down
No. You remove the lift arm levelers (I called them lift brackets in my last post, but I think this is what they are really called, they are the things that connect the lift arms to the hydro servo "ears"). This way the lift arms flop down. When you attach the bagger and tilt it up to connect the "top link" it rocks agains the lift arms and they lift up. If my description is still not clear and surfran doesn't have time to snap a picture I'll do so when I put it on in a week or two.
> Does it ever rub the ground (as my weights sometimes do when I transition a hill)
I really don't have any hills, but if anything would rub it would just be the bags and they hang so the wost that would happen is you would un-hook a bag. It would have to be a pretty steep hill to do so.
> How much did you have to pay (in your area / my mileage will vary )
Don't recall exactly but I think it was around $1600.
> Any grease zirks?
No, but others please check and correct me ASAP if this is not the case!
> Do you have to drill the deck, what holds the grass chute open on the deck
The boot attachment for a 60" and 54" deck are different. I'll post the instructions for drilling in a later post. There is a metal "ear" on the boot assembly that holds the chute deflector open. See the attached picture.
-- Rock
   / BX Grass Catcher #13
Rock! Thanks for the info! I hope you type fast,... I'd hate to think I'm taking up that much of your time! /forums/images/graemlins/wink.gif
   / BX Grass Catcher #14
Hmm... can't get the scan size right for the 54" and 60" boot installation instructions. On the 54" (which I have) you need to drill one hole (see attachment) for the boot pin, and widen the other hole for the bungee cord that holds the boot on (see previous picture). For the 60" deck you need to drill two .390" holes on the top of the deck spaced 3 3/4" apart 5 1/4" from the edge of the deck where the chute deflector spring is. Not sure how the boot connects.
In my previous answers I mentioned that there are no zirks. While I still beleive this to be true there is a gearbox that is going to eventually want an oil change and a PTO shaft and 3pt pins that would like a little grease from time to time.
   / BX Grass Catcher #15
I'm going to predict that I will scratch the hell out of my deck,... dull out 3 general purpose (read: barely good enough for wood) bits, kill 2 dewalt batery charges, and THEN drive to lowes and buy a real metal bit, dig out some extention cords and use my bosche drill. Eventually I may even center puch so that the drill doesn't wander,.... NAAAaaaaa... I can hold it! /forums/images/graemlins/cool.gif
   / BX Grass Catcher
To expand on what rock has said, but with limited experience so far.
The grass catcher does come off a little more difficult than I would like to have seen. I receievd my BX on a Sunday and promptly tried to remove it. I could not get the top pin out easily so I was going to hook up the lift arms to "easily" lift and take pressure off top link pin, but decided against it until I talked to dealer so I didn't damage.
Problem with Kubota manual is that it does a good job explaining how to install this thing on the tractor from out of the box, but NOTHING on how to take on and off normally!!!!!
Anyhow, I called Al Murray from Carvers on Monday and he indicated that you have to lift up on the unit to remove pin (hence rocks use of floor jack I suspect). Well I got out a hammer and drove pin out close to being removed and then lifted and removed it and lowered down onto support legs. This worked ok, but still was not as easy as I think it should be.
The bottom pins are no problem and the storage legs are great as well. Last night when I got home, I re-installed it. Contrary to rock, I left the lift arms on and first attached the bottom 3-pt arms and the PTO shaft, then standing on the right side CAREFULLY lifted the hitch to move the upper arm above the pin location (making sure it was centered before lifting). Then I rotated the catcher forward and put the pin in (this did take a couple of up and downs as the up is kinda quick some times). Afterwards, I lowered the arms to take pressure off them so I could remove the lift arms. I pulled the pins and wholla it was hooked up (well not totally). Actually then I had to adjust the lower links.
Hooking the catcher chute on and the bags are a piece of cake. Although as I mentioned, I am somewhat concerend on how long the "pin" will last that attaches the rear part of the boot to the deck (see rocks picture for hole it goes into in front of deck wheel).
I will post some pictures of this set up tonight.
Thats all for now.................
   / BX Grass Catcher #17
You guys with the 60" decks must have that hole near the back part of the chute already if it indeed mounts with a pin like the 54" deck (see picture for pin location on boot (all these pictures are from my old post)). The two holes that the instructions tell you to drill (Rogue, try a little WD-40 on the bit when you're drilling) for the 60" deck must be to hold the boot on instead of the bungee set up like I have.
I don't really mind the bungee as it is one of the heavy rubber kinds and I can take the boot on and off in around 5 seconds.
   / BX Grass Catcher
Rock and Rogue,
Here is my latest round of pictures. Rock, the two holes are for a deflection chute that you install on the deck. The 60" boot attaches the same as the 54" except the bungee hooks to the side hole on the deck anti-scalp wheel mounts.
Tonight I sheered the pin on the drive shaft, or it fell out. I am not sure, as I don't recall any loud noises, but suddenly it wasn't picking up leaves very well. /forums/images/graemlins/confused.gif Luckily I was pretty much done. I did hit some sticks during the endeavor, but don't recall any at that time.
Anyhow, Rock where do you get new pins? Can I get them at Tractor Supply Co? or do I need to get from Kubota? I think I will want several on hand if this is going to be a normal occurance (which I hope it isn't). /forums/images/graemlins/frown.gif
   / BX Grass Catcher
Here is the deflector shield attached.
   / BX Grass Catcher
Here is one of the chute with the pin as Rock also showed earlier. This pin is one of my concerns, as the plate is riveted onto the plastic and I wonder how long it will hold up.
On the fip side, it sure is easy to take off with the pin and bungee. I am used to my fathers JD 425 with the powerflo and it is slightly more difficult.
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
John Deere No. 5 Sickle Bar Mower (A50515)
John Deere No. 5...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51244)
KNOW BEFORE YOU...
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
