BX rear weight
   / BX rear weight #1
miker2702
Bronze Member
east tenn
bx2200
someone had a post and picture of a plastic garbage
can weight filled with concrete. i can not remember
if it was here? do it yourself? attachments? can
anyone remember where??
   / BX rear weight #2
Like this?
I made it myself. Picked up a cheap garbage can, a drawbar, some flat stock metal, and a few pins.
   / BX rear weight #3
The only thing I don't like about it you didn't paint the can Orange, HAHAHAHAHAHAHA!
   / BX rear weight
thanks zick great idea i have some left over golf tubes from a
rod tip divider in my boat if i can get them in there it might make
a tool holder also.
   / BX rear weight #8
Like this?
Guessing this makes a big difference when using your front end loader?? Also how is the tip factor when driving off camber?? Thinking of doing something similar....;)
   / BX rear weight #9
Big difference when maxing out the loader! Usually my rear comes off the ground long before I get the max weight in the bucket, but w/ the ballast that problem is gone. :D
Not sure about the tip factor as my land is pretty flat.
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
