BX22 Bagger for leaves
   / BX22 Bagger for leaves #11
Trac Vac
I had a Kubota mounted catcher for my BX2200--it worked fine but the capacity was way too small for my yard. After using the Trac Vac I can't envision ever using a tractor mounted catcher again.
   / BX22 Bagger for leaves #12
I have a Cyclone Rake which I use on my BX22 & 60MMM- with 1.5 acres of lawn (and leaves) there is no question about it - I would never ever go to a bagger that attatches to a tractor. The cyclone rake mulches the grass and leaves "after" being cut by the MMM so its processed twice - coupled wih the fact you have three size carts to choose from (I have the middle one) I can cut a fair amount of lawn / leaves before I have to dump. Every fall I look at my lawn and smile thinking of the days I used to use a leave blower - best dag money I have ever spent....outside of the BX that is! :)
   / BX22 Bagger for leaves #13
Since the bagger on my bx24 is a POS any thick leaves Ill rake into large piles then pull the boot off the deck, turn the rear PTO ON and use a 10" drain tile to go from the top of the shoot to the back of my dump truck then rack the leaves into the tube. Works pretty good! just get a few stares from passers by.
Ian
2016 CATERPILLAR 415F2 BACKHOE (A52709)
2016 CATERPILLAR...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58216)
2014 AMERITRAIL...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
Meyer 7.5' Snow Plow w/Bracket (A55272)
Meyer 7.5' Snow...
2016 Hyundai Sonata (A56859)
2016 Hyundai...
