BX22 Bagger for leaves
   / BX22 Bagger for leaves #11
Trac Vac
I had a Kubota mounted catcher for my BX2200--it worked fine but the capacity was way too small for my yard. After using the Trac Vac I can't envision ever using a tractor mounted catcher again.
   / BX22 Bagger for leaves #12
I have a Cyclone Rake which I use on my BX22 & 60MMM- with 1.5 acres of lawn (and leaves) there is no question about it - I would never ever go to a bagger that attatches to a tractor. The cyclone rake mulches the grass and leaves "after" being cut by the MMM so its processed twice - coupled wih the fact you have three size carts to choose from (I have the middle one) I can cut a fair amount of lawn / leaves before I have to dump. Every fall I look at my lawn and smile thinking of the days I used to use a leave blower - best dag money I have ever spent....outside of the BX that is! :)
   / BX22 Bagger for leaves #13
Since the bagger on my bx24 is a POS any thick leaves Ill rake into large piles then pull the boot off the deck, turn the rear PTO ON and use a 10" drain tile to go from the top of the shoot to the back of my dump truck then rack the leaves into the tube. Works pretty good! just get a few stares from passers by.
Ian
2022 ALLMAND NIGHT LITE (A58216)
2022 ALLMAND NIGHT...
2019 Komatsu WA470-8 Articulating Wheel Loader w/Quick Coupler, PIN# KMTWA129JJNA49506, Turbo Die... (A59076)
2019 Komatsu...
2007 Freightliner (A57148)
2007 Freightliner...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
Hydraulic Thumb Clamp (A57149)
Hydraulic Thumb...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
