Oil & Fuel BX2200 fuel tank leak
   / BX2200 fuel tank leak #21
Did you use only the service bulletin? I'm trying to get up the nerve to do this; I'd prefer something with step by step illustrations to go with the step by step instructions. It is self explanatory once you get down to the fuel sensor?
   / BX2200 fuel tank leak #22
There was an instruction sheet with the kit, I don't recall having any problems other then the clearance is a little tight inserting the sensor inside the tank. The service bulletin was of no help. If you can change spark plugs on a V8 engine you should be able to do this. An extra set of hands might come in handy for removing the ROPS.
Dave
   / BX2200 fuel tank leak #23
new to the site and love the wealth of knowlege.I have just purchased the repair kit from my local dealer this morning and have just finished installing it up to and including the point of remounting the bolt on angle bracket under the tank when I realized that the old piece had a gasket between it and the actual sending unit. Needless to say I didn't transfer this gasket to the new piece and I can't see where the instruction sheet says it is necessary.The thing I can't get my mind around is how does the fuel not leak between the sending unit and plastic collar if there is no gasket . Maybe I'm just being **** about it but I don't want to have the same problem that I just spent 1.5 hrs to fix after I'm done. At the same time I don't know if it worth pulling the sender back out to put this gasket in if it is not necassary. Any advise would be greatly appreciated
   / BX2200 fuel tank leak #24
quick66,
A new gasket should of came with the kit, it did with mine. Without that gasket it will leak again. Replacement kit #K2561-96140.
Bill
   / BX2200 fuel tank leak #25
I had my bx22 done /fixed last fall. It is a simple and cheap part but the problem is getting to the part. Poor design.
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2006 Chevrolet Express 2500 Cargo Van (A51692)
2006 Chevrolet...
