Oil & Fuel BX2200 fuel tank leak
   / BX2200 fuel tank leak #21
Did you use only the service bulletin? I'm trying to get up the nerve to do this; I'd prefer something with step by step illustrations to go with the step by step instructions. It is self explanatory once you get down to the fuel sensor?
   / BX2200 fuel tank leak #22
There was an instruction sheet with the kit, I don't recall having any problems other then the clearance is a little tight inserting the sensor inside the tank. The service bulletin was of no help. If you can change spark plugs on a V8 engine you should be able to do this. An extra set of hands might come in handy for removing the ROPS.
Dave
   / BX2200 fuel tank leak #23
new to the site and love the wealth of knowlege.I have just purchased the repair kit from my local dealer this morning and have just finished installing it up to and including the point of remounting the bolt on angle bracket under the tank when I realized that the old piece had a gasket between it and the actual sending unit. Needless to say I didn't transfer this gasket to the new piece and I can't see where the instruction sheet says it is necessary.The thing I can't get my mind around is how does the fuel not leak between the sending unit and plastic collar if there is no gasket . Maybe I'm just being **** about it but I don't want to have the same problem that I just spent 1.5 hrs to fix after I'm done. At the same time I don't know if it worth pulling the sender back out to put this gasket in if it is not necassary. Any advise would be greatly appreciated
   / BX2200 fuel tank leak #24
quick66,
A new gasket should of came with the kit, it did with mine. Without that gasket it will leak again. Replacement kit #K2561-96140.
Bill
   / BX2200 fuel tank leak #25
I had my bx22 done /fixed last fall. It is a simple and cheap part but the problem is getting to the part. Poor design.
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A53472)
John Deere 1110...
Versatile 500 (A53342)
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
