BX2350 Lights on Rops - FEL work at night
   / BX2350 Lights on Rops - FEL work at night #21
fishpick said:
I like it... So, JEW, as I understand it... there is a loop in the wire inside the ROPS to hopefully prevent it from getting crunched when raised or lowered... humm, my plans might be a changin... ;)
Here are some additional pictures of how the light pattern projects from the ROPS. When I've used my BX at night I have a very good pattern and peripheral light for seeing around you as well. The illumination is good because the lights shine from above your head.
To assemble the ROPS with the insulated wire inside the tubing, with the ROPS unassembled at the pivot point, I inserted a loop of wire into the base (where it attached to the frame), and then pushed a loop back into the upper section of the tubing around the pivot bolt and then fished the line down the base and out the hole that I drilled. The key is to have enough slack and allow the wire to rest around the bolt so when the ROPS pivots the wire does not get pinched.
As you can also see the wires are totally contained within the existing cable run. The connection is located just behind the auxillary hrdraulic connector for the BH. The wires at the switch have heat shrink tubing around them to waterproof them as well as protect them from any stray fingers from touching bare wires, even though it is only 12vdc.
   / BX2350 Lights on Rops - FEL work at night #22
Check out the link in my signature to my BX2350 photo album. I just updated my WebShots site with my ROPS light project. A pair of traps looking forward and floods looking back. I love the setup.
   / BX2350 Lights on Rops - FEL work at night #26
I have a BX2230 - how do I tell if it has a HD alternator on it ?
If so what is the max lights I should put on it?
LPP
   / BX2350 Lights on Rops - FEL work at night #27
Those look fantastic. I don't see myself doing much nighttime work at the moment, but if that changes, I'm going to have to go with a setup like yours.
   / BX2350 Lights on Rops - FEL work at night #28
LPP, the 2230 came standard with the dynamo, a lot smaller and much different looking from the alternator, which looks similar to what's in your car, just smaller. Without it, you can still put on some lights, but remember that your pulling on the battery, since the dynamo only puts out like 15 amps at full RPM vs 40 for the Alternator.
Singlecoil, keep in mind that the BX24 has a much larger ROPS, so the way he has those mounted may not work on the 2350 without getting your head smacked by them.
   / BX2350 Lights on Rops - FEL work at night #29
Musclford said:
Well, I understand what everyone means about using the BX with FEL at night...
Difficult to see at all times, so I'm ready to add some lights.
Any Suggs? Doesn't the BX have a true alternator, instead of a generator??
I thought I had read somewhere that they upgraded the BX2350 from the BX22** so you could add more lights without upgrading the alternator?
I was thinking of adding some of the little Fog lights you can buy at Autozone / Wal-mart.....
Thanks!
Phil
Re: Lites on youe tractor
Here are some thoughts I've been kicking around concerning lights on rops.
1. Use two lights rather than 4 lights. Mount them on a light bar that will swivel the lights up and down. I install the lights on the bar in a manner that will permit the lights to be rotated 360 degrees. The 360 degrees allows you to have light to the rear and front or both to the front or both to the rear.
Use magnets to mount the brackets for the light bar to the top rear edge of the rops instead of on top of the rops or under the top of the rops. Next bolt the ends of the light bar to the brackets with one bolt through each bracket into the bar.
Tighten the bolts just enough to hold the bar in place but loose enough to move it by hand. The swiveling light bar allows:
(A) Allows adjustment of the distance the lights shine out from the tractor.
(B) Gives more clearance above the lights and more head room under them.
(C) Lessens the chance of catching the lights on something overhead.
(D) Allows the lights to flip down if hit rather than breaking them.
(E) You can just flip the lights down to work under low hanging branches instead of having to remove them from the rops. However you still have the option of removing the bar and lights and unplugging the trailer connector.
*Advantages of the 360 degree rotation *
(A) Permits two lights instead of requiring 4 lights, thus reducing current flow.
(B) Lights can be turned both to front or both to rear. Or they can be turned one to front and one to rear. They can also be used for side lighting. Swiveling lights can provide illumination 360 degrees around the tractor.
Adjustment from one position to another is instant by hand. No wrenches or tools required.
A low profile light preferred over high profile lights.
I've been using this system of combining a rotating light bar with swivel mounted lights to install fog and driving lights on my pickups successfully for years.
More thoughts on lights.
Use a dual direction light with a clear lens on both sides that will cast light to the front and rear at the same time.
Thinking about experimenting with a hanging swing light magnetically attached to the cross member of the FEL to illuminate the bucket shadow when using the head lights.
L.B.
I would not disconnect the head lights but would run the extra lights connected to the key on side of the ignition switch and a separate switch in the line between the connection and the lights. You could also use a switch for / on each light if you desire to control each lite separately.
The reason I prefer going through the key switch is because you can't forget to turn the lights off and run the battery down.
I use a 10 AMP Fuse.
   / BX2350 Lights on Rops - FEL work at night #30
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
