Have you come across a job that the BX was too small for? The way I see it, everyone can want a bigger tractor and even be upset they didn't get a bigger one but in a lot of cases you can make it work. I am a hobby farmer, I have to make things work all the time because I don't have the money to buy everything, so far I have been successful in everything I have set out to accomplish, a few times I had to get pretty clever. For my needs around my house taking care of cattle and chickens my dads 445 2wd JD worked plenty good, I stretched chainlink with it, pulled trailers ext. I found only 1 job I needed a compact for and that was to feed round bales to the cattle, in order to be more efficient with feed costs this is the route I decided to go and to be honest I wanted the tractor more than needed lol. A BX is about the same size as my dad's 445 and I would be plenty happy with it on 3 acres. Maybe try not to think of it as you bought too small of a tractor, maybe look at it as your clever enough not to need a bigger tractor and you step up to the challenge to get it done with a smaller tool. All a tractor is, is a simple machine. It's a lever (FEL) mobile thanks to wheels and axles driven by gears, you can increase the capacity and get away with less machine thanks to basic planning and leverage. My grandpa did everything with block and tackle, he died before I was born but I heard some pretty amazing story's of what he accomplished with just that. So in that case if you did run across something the BX couldn't lift, some lumber framed up, with screws hooked to rope and pulleys (block and tackle) is cheaper than another tractor and can still let you get the rest of the work done with the BX. There's a lot of satisfaction in solving a problem with less resources.
