You stated that you purchased 2 pair. Are you mounting all 4 forward, 2 forward, 2 back? I'm thinking about ordering a set of floods to face the rear.
I'm mounting two forward and two back. When you order them as "Pairs" they ship with a wiring harness and switch that control BOTH lights at one time. If you order them as one individual light, it ships with the harness and switch for just the one light.
It's more money to order them individually, BUT, if you want to be able to control each light separately, thats the way to go.
But I will be turning them on and off as a set, so no matter to me.
If you only order one "Pair" and decide you want to control them individually, you can order another "single" harness directly from Rigid.
I had them temporarily mounted on my ROPS and they are freakin' bright !
I plan to mount them a little more permanently now that Winter is coming and I have the corrugated wire loom to run the wire in to make for a cleaner installation.
Since I want to remove them when I cut grass due to the low tree branches, I plan to use some big battery alligator clamps to hook up directly to the battery. It should be an easy on, easy off arrangement.
I have two different mounting brackets to choose from and have not decided which one I will yet, but am leaning towards the U-Bolt mounts.
I have a set from Messicks which is real quick and easy to mount/remove. No tools needed:
General / Case 2X3 LGHT BRKT Part #3582
I also have a set of the U-Bolt brackets I bought from TractorCabDepot, but they dont carry them any more. I was able to find another place that has them. They are real heavy duty brackets, but you need tools to mount them:
ROPS Mounted Light Bracket (pair)
I have a strange gut feeling that the Wiedmannbros site is somehow linked with TractorCabDepot.
Anyway... those brackets are sweet !
