BX25 vs BX25D FEL?
   / BX25 vs BX25D FEL?
Smibota,
What kind of problems are you having with the QA and bucket?
I had to drill out (ream) a pin hole for one of the pins. I did it with the bucket on the QA. The pin was hard to put in and out, ran a drill through it and works great now. I don't have any problems attaching my bucket or mini forks.
   / BX25 vs BX25D FEL? #22
After reading this thread so isn't out and checked the QA on the FEL of my BX 25-D. Yes there's a gap but nothing excessive in my opinion. I figure about 1/8th on each side of the gap. I would expect it yo be that much making assembly easier.
As for using the QA. I wiggle the bucket and just push the pins in. Pretty good system in my opinion.
4shorts,
I installed the bronze thrush washers to keep the grease from squishing out. Mine looked like yours.
The hole I reamed out are for the removable quick pins only. It was only on one side. Just made it easier to work the pin.
   / BX25 vs BX25D FEL? #24
4shorts,
:cool: sounds logical. That QA is a nice system. :thumbsup:
   / BX25 vs BX25D FEL? #25
As I said in my previous post the bucket does not go on and off smoothly, I have to really fight the bucket on and off. The bucket and the QA plate are solid welded structures so I don't think there is a alignment issue! (Installed this in my garage on a flat concrete floor). I am very familiar with quick attach systems as I had a Air2 QA (now the Jari system) on my 2009 BX2360...the bucket and pallet forks went on and off very smoothly (never had to get off the tractor for the pin holes to line up). I think I may have a QA plate that wasn't assembled-welded correctly. My dealer is looking in to it! Also I might add that the quality of the Kubota QA system is excellent!...some piece of steel!
Mini Plate (A57149)
Mini Plate (A57149)
208320 (A58375)
208320 (A58375)
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
2006 Freightliner Auger Truck (A56436)
2006 Freightliner...
