BX2750D Snowblower chute actuator project
   / BX2750D Snowblower chute actuator project #13
mjribeiro, like tiredguy, I've been contemplating the same modification. In fact, I was zeroing in on the same actuator that you used and like you, I was thinking of rear mounting. Your side mounting job was beautifully executed :thumbsup:; thank you for the blueprint. Please report back after a good test (if it ever snows again) to let us know how it worked.
Dean
   / BX2750D Snowblower chute actuator project #14
I don't even have a blower (yet) and I was curious how it worked. I've seen quite a few mods here with electric and hydraulic. I can't help but wonder if an actuator on one side is in danger of bending up one side should the other side lock up for some reason. :confused:
Otherwise :cloud9:
   / BX2750D Snowblower chute actuator project #15
Just purchased my rocker switches from AEI and the Powerlet outlets. I have a GR2707 with the chute rotator/defector kit and did not like the clunky metal toggles that Kubota supplies - this stuff looks much more OEM. Thanks for the tips!
Otherwise :cloud9:
I used lock nuts and Teflon washers on the two 'sliding' joints on the sides. I could see those sides getting loose or tight with a regular nut, but it should stay the same with the lock nut. I will watch that over time.
   / BX2750D Snowblower chute actuator project #18
I used the same actuator as you did but a slightly different different setup on my B3030:
It does have a tendancy to flop a little in action. You can see what I am talking about in this movie I made and posted on YouTube. I will evaluate how it holds up at the end of the season:
Kubota B3030 HSDC snowblowing Jan 2012 (HD) - YouTube
   / BX2750D Snowblower chute actuator project #19
The flopping can be stopped by putting a bolt and some nylon washers there at your spout pivot (picture below). I put a nylon washer on the outside and in between the chute and the spout. Use a crimped nut (or one with a nylong insert) so you don't have to tighten it very tight and the flopping stops.
My spout moves freely with no stress on the hinge and no wobble.
I noticed there is a generous amount of clearance in the hinge assembly. Without the knobs keeping the deflector in place mine has a decent amount of movement even without the actuator. If it really starts to bother me I could put a larger diameter hinge pin in there, or replace the hinge entirely - I'm thinking I can live with it!
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
Adams 6T Fertilizer Spreader (A56435)
Adams 6T...
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A58214)
2012 JACK COUNTY...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
1983 KENWORTH W900 SLEEPER (A58018)
1983 KENWORTH W900...
2003 Big Tex 10PI...
