cable tangle
/ cable tangle #1
Mutton98
Im am having troubles with my new winch cable getting tangled and very hard to pull out. Im very careful not to real it in with out tension on the cable could it be the cable is new? if anyone has any tips it would be apreichated thanks
/ cable tangle #2
What kind of winch do you have? As you suggest, maintaining cable tension while pulling toward the winch is the key. Unwind it completely then slowly rewind it with significant tension by pulling something that weighs several hundred pounds. I do this occasionally when mine starts to tangle. I've noticed that I have had less problems recently but I don't know if I'm being more careful or if the cable is being more cooperative as it gets used. I've had mine jam to the point of having to pull against something to pull the cable loose. As the cable gets used it is almost impossible to avoid a few kinks or rough spots which can also lead to this problem. Sorry I don't have a cure for this, I hope someone else will have a better response.
/ cable tangle #4
I have a Warn with 80 feet of really stiff cable and if I don't have lots of tension on It all the time It will "birdsnest" and I have to feed It all out and start over again with tension on It, I use real heavy gloves for this
It's tricky but It can be done safely, be careful
Jim
/ cable tangle #5
Assuming you are talking about a 8000lb winch, it will get better. You can speed up the process by letting your cable out to the first layer and then dragging your vehicle (brakes on, in neutral not park) across a parking lot with the winch (heavy load on the cable) this tends to help break it in.
When you are using your winch always try to keep the cable straight out in front so it can wind on smoothly. You may have to guide it a bit from side to side with a gloved hand or boot. BE carefull while doing this and keep at least 3' in front of the winch. If it is a real heavy load, then stand clear !!!!
If you must pull from the side, then be prepared to stop when the cable piles up, unwind some and wind it onto the far (MT) side, then let the cable tighten up where it will while you pull a bit more. If the cable does pile up too much on one side it can get jammed to the point where you will have to pull it out with another vehicle (if yours is stuck)
When powering out your cable never let the winch spool out faster than you are removing cable. Hitting the "out" button without watching the spool kills cables quick...So does hitting the wrong button.
There are many tricks to getting the most out of your winch. The Laws of Physics are involved with most of them.
Some of the handiest items to have are a snatch block (pulley), short nylon sling to use when winching from a tree or anchoring your pulley, a 2" screw clevis (used to hook the cable to the sling loops) and a short piece of good chain with a grab hook on one end and a slip hook on the other for those times when the stuck vehicle doen't have tow hooks and you must hook to the axle/leaf springs/ bumper brackets. Have fun.....
/ cable tangle
thanks for the info thats what i figured with the new cable, the winch is a norse 290 logging winch thanks again
2011 Takeuchi TL250 Compact Track Loader Skid Steer (A64553)
2011 Takeuchi...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
1999 Trailmaster Aluminum 407 T/A Chemical Tanker Trailer (A64194)
1999 Trailmaster...
2022 EZ-GO ELITE...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
