Can I run a Cat 2 mower on my Cat 1 tractor?
   / Can I run a Cat 2 mower on my Cat 1 tractor? #11
my bad, My dyslexia kicked in and I got it backwards. the other gentlemen are correct on changing pins. before I did that I would take some measurements and buy a quick hitch from harbor freight.
A couple of thoughts on this. Check first to make sure the mower is a new enough model to work with a mono-frame quick hitch. Also, last I knew, Harbor Freight only has a Cat 1 quick hitch. That'll work on the OP's tractor, but will probably be too narrow overall in width to match up with the Cat 2 mower unless he can reverse the pins of the mower so they point inward. If reversing the pins solves the width issue, it should work, as the HF quick hitches that are now being sold have hooks large enough to handle the Cat 2 pin diameter.
   / Can I run a Cat 2 mower on my Cat 1 tractor? #12
I am running a cat 2 sprayer on my cat1 kubota. As mentioned, you will need the adapter pins for the lift arms ( 1 1/8 threaded section, 7/8 pin) you will also need something to keep the cat1 top link pin from sliding out of the cat2 holes in the cutter. I used 3/4 flat washers at each end of the pin. Another alternative is getting a cat2 to cat1 top link bushing and cutting it in half to go through the cutter using a cat1 pin.
   / Can I run a Cat 2 mower on my Cat 1 tractor? #13
And tighten those pins good so they don't loosen with vibration. Lots of stress is located right at the pins. And tell your neighbor your plans of course!
Jim
So, I went in to the local industrial shop that deals with tractor supplies (according to every other shop in town that I tried). I explained to the guy what I wanted and he looked at me funny saying he'd never heard of such a thing before, but he'd get in touch with his dealer in Prince George BC. I heard back from him yesterday and he said they'd never heard of this before either.
So at this point, I've tried using the net to find these things to order online but I'm having no luck, not even with Princess Auto's webpage. Could anyone lend a hand and help me find a place to order these things online?
   / Can I run a Cat 2 mower on my Cat 1 tractor? #15
Attached is a handy 3-point cheat sheet courtesy of New Holland.
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
