Can I Seal a Deck?
   / Can I Seal a Deck? #31
From the reflections in your window glass it looks like you may actually be looking at Lake Martin from the deck.
That is correct. And I enjoy that deck!
   / Can I Seal a Deck? #33
Yeah, those pictures with the line where the wall is under neath really do help.... you're in deep doo-doo! :laughing:
Just kidding.
But as others have mentioned, you're going to end up having to remove the decking and make a solid floor (or roof, depending how you look at it), and then put the deck back.
Or, as you mentioned, get that manufactured interlocking decking, but it will change the look of the deck a lot with the boars running perpendicular to the house. Not saying it will look bad... just look different than you're used to.
   / Can I Seal a Deck? #34
Well there are a number of ways to fix the issue and some good ones have been suggested. I till think I would go with the rubber backed nylon indoor/outdoor carpet. It would cut the wind and shed the water away from the crawl space. You are in the same climate zone I am so sever cold and snow are not the big issue. The carpet can be glued down or laid loose with carpet edging strips. If you wanted to go a step farther you could lay down 1/4" tile backer board and glue carpet to that. It would be hundreds cheaper than some of the suggestions. And hey...if it doesn't work the other options are still there. With the crawl space unsealed insulating the floor joist under the houses living areas would also help the comfort issues.
MarkV
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A51246)
2020 CATERPILLAR...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
UNUSED AGT QUICK ATTACH 72" VIBRATORY ROLLER (A51248)
UNUSED AGT QUICK...
