Can I Seal a Deck?
   / Can I Seal a Deck? #31
From the reflections in your window glass it looks like you may actually be looking at Lake Martin from the deck.
That is correct. And I enjoy that deck!
   / Can I Seal a Deck? #33
Yeah, those pictures with the line where the wall is under neath really do help.... you're in deep doo-doo! :laughing:
Just kidding.
But as others have mentioned, you're going to end up having to remove the decking and make a solid floor (or roof, depending how you look at it), and then put the deck back.
Or, as you mentioned, get that manufactured interlocking decking, but it will change the look of the deck a lot with the boars running perpendicular to the house. Not saying it will look bad... just look different than you're used to.
   / Can I Seal a Deck? #34
Well there are a number of ways to fix the issue and some good ones have been suggested. I till think I would go with the rubber backed nylon indoor/outdoor carpet. It would cut the wind and shed the water away from the crawl space. You are in the same climate zone I am so sever cold and snow are not the big issue. The carpet can be glued down or laid loose with carpet edging strips. If you wanted to go a step farther you could lay down 1/4" tile backer board and glue carpet to that. It would be hundreds cheaper than some of the suggestions. And hey...if it doesn't work the other options are still there. With the crawl space unsealed insulating the floor joist under the houses living areas would also help the comfort issues.
MarkV
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
IRGC40 Electric Tricycle (A55758)
IRGC40 Electric...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
Giyi Pile Hammer (A53316)
Giyi Pile Hammer...
