Can someone fill me in on this B7100 info?
   / Can someone fill me in on this B7100 info? #11
Gary,
My 1996 B7100 HST has a RC60-71B deck, did you just get the numbers reversed ?
I'll be happy to send you pictures of the left side as soon as I get a few free minutes. We might be neighbors, I'm in Grafton,WV. If that's close your welcome to stop by and look. Let me know and if needed I'll take a few photos and send them.
Casey
yes, that's the same deck I have.
awesome - I'm in Morgantown, so we are neighbors. my schedule sucks now since i'm working full time and watch our daughter while my wife works but I would love to spin down there and have a look at it. that would definitely work.
i guess we should PM some phone numbers or email addresses, what's the best way to get in touch with you?
Looks like Mr. Whitty and myself will get together some time and sort this out. Thanks!
I was going to take a picture and post but the camera batteries were dead, that thing is a hog.
   / Can someone fill me in on this B7100 info? #14
Here are the photos as promised...
thanks a bunch biffo, something is definitely up with mine. oddly enough it does "work", though i don't know how. the mounting hardware looks completely different than that, wonder if a previous owner just made something for it.
   / Can someone fill me in on this B7100 info? #16
Grossgary -
I think Biffo has a different mower with a much different mounting system. My original B7100 mower, Model MR6000 used that mounting. I think they called it parallel linkage. I don't know the number of Biffo's mower, but the later B7100's had a RC60-71B, I believe. His mower appears to be a model they offered in between the MR6000 and the RC60-71B. I put the RC60-B on mine even though it was made for a later model tractor, I think a B2400 if I recall correctly. It was not too difficult to mount. The biggest problem was fabricating the rear mounting brackets. The front hanger bracket pretty much bolted on with only a few modifications.
The older parallel linkage mounting had a tendency to wear a lot. With it the mower was actually pushed by the parallel linkage, whereas the mower is pulled along from the front mounting bracket on the newer mowers. What I miss most from the old MR6000 was the height adjustment lever. It was much more convenient than adjusting each wheel separately as on the newer models. The newer mower cuts better also.
I also put a separate cylinder on mine to raise the mower independently from the 3 pt. hitch. I just turn the valve under the seat to operate either the mower lift or the 3 point. I had a 3 pt. grass catcher on mine, and that was the only way I could raise and lower the mower without the hitch going up and down.
I have since transferred the catcher to my John Deere. On it I took the lift arm off and replaced them with chains. That way the 3 pt. hitch arms hang from the chains and do not go up and down with the mower. I don't use the 3 pt. for anything else on the John Deere.
Here is a photo of the MR6000, but I can't get it to come through very good.
   / Can someone fill me in on this B7100 info? #17
The deck model number is RC60-71HR with a serial number of 10705.
I believe the mower to be from the late 1990's or later but not too sure on that, the tractor is from the 1980's.
The fact that it's a UK tractor and deck shouldn't make any difference should it? I can't see why when model numbers tie up.
If you need any other detailed photos just shout, it's no problem.
Jamie
Thanks guys, I'll have to look into this, mine is obviously different than that, but maybe it's not wrong? I'll try and post a pic.
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56438)
LIKE NEW 2023...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
167 (A52708)
167 (A52708)
30KW GENERATOR (A58214)
30KW GENERATOR...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
