LBrown59
Super Star Member
- Joined
- Oct 27, 2004
- Messages
- 16,831
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
swmpbgy1 said:Yup.....ups the posting ante!![]()
Swmpbgy1
Swmpbgy1
NuBota said:I've been flirtin' with the 25+ gal caddies for a while, but had the same concerns about weight, transporting, durability of hose/pump, etc.
But you make a good point about the 14 Gal there Old School - is the hose and pump pretty solid? I just picture potential leak points......
drtydeed said:You guys with the yellow plastic spill proof cans- does your can stop flowing? Mine does it all the time..I get the glug, glug, glug ..i hate it! It takes 5 mins to empty the can. I know that there is a plastic breather inside, but I think mine is deffective.
Not sure if this is the correct forum but, is there any factual basis for not storing fuel cans on concrete floors? I've heard it many times, but can't understand why that would be more susceptible to moisture contamination. Anyone have a truthful explanation?
drtydeed said:Not sure if this is the correct forum but, is there any factual basis for not storing fuel cans on concrete floors? I've heard it many times, but can't understand why that would be more susceptible to moisture contamination. Anyone have a truthful explanation?
rpoage said:5 sequential replies on the same thread must surely be a new record for TBN.![]()
Yes it will stop. BUT if I adjust the height of the can (usually up) the flow will start again. With some practice (I'm approaching 200 hrs since mid-Aug) I find that I can cause the breather mechanism to bubble continuously which seems to make it empty fasterdrtydeed said:You guys with the yellow plastic spill proof cans- does your can stop flowing? Mine does it all the time..I get the glug, glug, glug ..i hate it! It takes 5 mins to empty the can. I know that there is a plastic breather inside, but I think mine is deffective....
TalonDancer said:Yes it will stop. BUT if I adjust the height of the can (usually up) the flow will start again. With some practice (I'm approaching 200 hrs since mid-Aug) I find that I can cause the breather mechanism to bubble continuously which seems to make it empty faster
Talon Dancer
Maybe that's the problem. You did do your fuel can break-in maintenance at exactly 50 hrs didn't youdrtydeed said:Ha, I think that I have 200hrs on the fuel can alone!
