Car Hauler vs Utility Trailer
   / Car Hauler vs Utility Trailer #42
I've got a really old 10k 20' equipment trailer, a 7k 18' car hauler, and an 18' enclosed motorcycle trailer. I'm thinking about selling the car hauler and enclosed trailer and getting a 14k 20' aluminum gooseneck. The new Yanmar is too heavy for my car hauler, and the old equipment trailer is going to my son along with the Kioti.
The reason for aluminum is weight savings. My truck is a Nissan XD, kind of between a 1/2 and 3/4 ton truck. Max towing is higher with a gooseneck, but still only 11 or 11.5k. Never towed with a gooseneck but my understanding is it's better than bumper pull. This setup would give me ~8500 capacity which would be enough for the tractor with implements.
Anyone towed with gooseneck and can share experience?
One tip on rails: My car hauler doesn't have them, 2 weeks ago I loaded (drove) my 76 Bronco onto the trailer. Without getting into the long explanation of why, the front passenger tire ended up going off the side of the trailer in front of the fender. Didn't do any damage to the Bronco, only a minor dent in the trailer fender. Needless to say, even a small rail would have stopped this, and the trailer will have rails before I haul another car/truck. Getting the Bronco back on the trailer solo was not fun!
   / Car Hauler vs Utility Trailer #43
I have a gooseneck stock trailer. They handle so much better than a bumper pull. They put the tongue weight in the truck bed over the axle, not at the rear of the truck. You will enjoy it. My 20’ trailer is a bumper pull only because I got such a good deal on it an the goosenecks were considerably more.
   / Car Hauler vs Utility Trailer #44
Have a 16 ft. utility trailer. Haul a TC34DA New Holland 35 miles each way on regular basis, Top rail and ramp fabbed with 2" sq. tubing instead of angle iron. Worked well for almost 20 years. Do use jack stand at rear of trailer when unloading or tractor will pick up rear axle of trailer
   / Car Hauler vs Utility Trailer #45
I had a 32' bumper pull toy hauler. Weight distribution hitch, many passes over a Cat scale, fiddling with weights, etc. it was always a white knuckle affair over 65. Sold it & got a 35' 5th wheel toy hauler (actually had a gooseneck hitch on it). Steaming across Wyoming at 70 with gusting 50mph crosswinds was a bit annoying. Far better than the best trip with the bumper pull at 65 under ideal conditions.
That's one case study though.
Goosenecks cut corners when turning, so you need to go way wide. They are also heavier, so depending on your limits the extra 500+ lbs may be a problem. They also put more weight on the truck. But that weight really only impacts the rear axle. On a bumper pull hitch weight unloads the front truck axle & puts it on the rear. On my 5th wheel/gooseneck, 2,500lbs of pin weight adds 2,440lbs to the rear & 60lbs to the front.
With my old bumper pull 1,500lbs of tongue weight unloaded the front something like 1,000lbs. With the weight distribution hitch on it still unloaded the front 3-400lbs if I recall. So 1,500lbs of tongue weight could add upwards of 2,500 lbs to the rear axle.
I'm about to put a flatbed on my truck because the bottom of the trailer has touched the bed side on some rough roads or camp sites. I knew it was close, so just inching a long. Backed out & took a different route or stacked boards under tires. Have yet to even scratch anything, but gonna get a flatbed to eliminate the bed sides as a limit. You have more range of motion with a gooseneck, but some additional potential issues.
   / Car Hauler vs Utility Trailer #46
I do think that recommending a 5th wheel to a guy looking to transport a sub compact is kinda bad advice.
   / Car Hauler vs Utility Trailer #47
Wasn't completely my intent. They do have their downsides. In the situation above the extra weight of the gooseneck & the fact they have more pin weight may or may not push him over payload or rear axle capacities of his truck. You have to do the math & get weights off scales. The math isn't that hard once you do it a few times, but getting the weights without the trailer or load & not having experience to estimate them can be.
   / Car Hauler vs Utility Trailer #48
With any twin axle trailer, getting things leveled well, with hitch height, whole loaded to normal operating wright helps. Lot of tow vehicles now need a drop hitch.
What is our OP using as a tow vehicle? You don't want to be pulling a 4000# trailer when you pick up 500# worth of stuff. At the same time, you don't want the lightest trailer made. I'm guessing max weight on his scut is 4,000#, with impliments, loaders, weights, fuel, ect? I think a 7000# capacity trailer is a good fit. Car hauler type would be good cause you have pretty good tie down options for a flat deck, and you generally also have a front "stop" between the deck and tongue.
Pallets can be loaded forward of the axles, if lighter, like feed, but when we get to shingles, quikcrete, ect, at like 3600# we are punishing the truck.
   / Car Hauler vs Utility Trailer #49
Wow, autocorrect seems to want to change Weight to Wright; Tow to Town, and mine has always wanted to turn For into Foe...
   / Car Hauler vs Utility Trailer #50
I had a similar option in 2019, because the Honda SxS was too wide to fit on my little 5x10 trailer. At the time, I had the Kubota L285, but not my Kioti, and the only time I had ever moved the tractor was on initial purchase. I went with a 6'4"×16ft landscape trailer from Texas Trailers, but there was also an option to get a ATV trailer that had a side gate, at the front, for pulling a ATV on crosswise, as well as the rear gate. Price was similar, maybe $200 more for the ATV style, or like $900 more for the car hauler. The utility trailer does Work, and I have had a 2012 Durango SXT on it, and Volkswagen Passat, the Honda 700 pioneer, and the Kioti Ck2610 multiple times. The rails are great for moving "stuff", but it makes it horrible to go pick up a couple pallets of singles or quikcrete. The rear gate/ramp, is removable and can also fold flat in, for less drag, But the ramp/gate really isn't heavy duty enough for what i use it for. It "works" for now, but eventually it will need reinforced, or rebuilt. The rear ramp on my 5x10 was actually heavier duty.
So, if you get the utility style, look for one with heavier than 1x1 tube steel. I have seen ones at Rural King that have round tube sides, that can be folded or removed with snap pins fiestas de cumpleaños para adolescentes. My concern would be, are those removable tube rails heavy enough to secure stuff too?
thank you so much for your suggestion
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
2012 DODGE DURANGO SUV (A52576)
2012 DODGE DURANGO...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A51692)
2002 Western Star...
