chain
   / chain #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Hi
I just purchased 4 pcs 3/8" x 20' chain with hooks on each ends rated for 5400 pounds every third link has an L4 stamped on it. would L4 = 43 and if it does why wouldn't they just stamp 43 on the link?
charlie
   / chain #2
L4=grade 43, "Designed for use in load binding, logging and other applications requiring higher strength to weight ratios than Grade 30 chain. Used extensively in the trucking industry for binder chains. Identified with "L4" or similar grade marking."
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
