jcummins
Veteran Member
- Joined
- Jan 14, 2007
- Messages
- 1,637
- Location
- Creal Springs, IL
- Tractor
- Kubota M7040, F3680, Mule Pro Fxt
Power on light on......signal light off. Browser into it, says connecting.
Master reset will not force you to deal with AT&T. It require you to deal with any setting changes you've made.This is getting annoying. Mine keeps having to be cycled after brief periods of inactivity. Both LEDs will be lit but no data throughput is possible without unplugging and restarting the Mobley. Twice yesterday afternoon, once again this morning, and just now after I was on the internet not 15 minutes ago. Network connection on my PC will say connected but will get the little yellow triangle on the icon indicating it has a problem. Unplug the Mobley and restart it and it works fine as long as I am using it. Let it sit a while and no connection even though everything says it's connected. I verified it is the Mobley by using my cell phone and trying to open a page with wifi turned on and it will fail. As soon as I restart it all works again until I let it sit idle.
Dang thing worked without interruption all yesterday until I tried connecting the router. After that this started happening but may just be coincidence.
If I do a master reset on the Mobley will I have to go through ATT to get it back on or will it still have the same number and just need the time out reset?
I had 8 days stable use....then a bunch of instability. This morning it looks good, so I'm not sure the long term stability of this setup.
It arrived, no power supply included. Box seal has been opened already.I have a GL AR300M coming from amazon today.
