Cheap Bridge idea
/ Cheap Bridge idea #1
Catch95
Australia
Jinma 204
I'm replacing an old timber creek crossing at present. After much reading and talking to others in the area, I've decided to use a flat rack (sometimes called flat deck) container. They are used here by emergency services for crossings when bridges are washed away in floods etc. I've attached a couple of pics - one in its raw state, and one that has been turned into a great looking bridge by a container company.
Obviously come in 20 and 40 foot versions.
Anyone else done this?
Mark
/ Cheap Bridge idea #2
That is a good looking bridge for sure. And should hold a lot of weight.
/ Cheap Bridge idea #7
/ Cheap Bridge idea
Sorry for not getting back to you - night time over here!
The are 8 foot wide. They would be available anywhere in the world that uses shipping containers. Some people prefer flat decks known as bolsters - same size, just don't have the fold down ends.
This link shows the diferent sizes etc Intramar Australia
From a container re-seller I was quoted around $2,000 (AUD) for a 20' and about $3,000 for a 40' bolster. The shorter ones can go on a tilt truck and be slid off easily - but generally these guys are so used to transporting containers, transport isn't an issue.
Will post some images when I get going with building the bridge.
Mark
/ Cheap Bridge idea #9
I have exactly the same problem (old wooden bridge) and had been thinking of using the bed from a flat-bed truck or trailer. This solution might work out cheaper, though.
Thanks for the idea,
BOB
/ Cheap Bridge idea #10
I used a 20' steel truck bed for a bridge across a creek on my property. It actually has 4' sides, & once in place we used a torch to cut out the forward bulkhead. I drive over it with a 40 horse tractor & in 4 years it has not budged. There was no cost involved because it had been left in one of my fields by the P/O, so I just drug it to the edge of the creek, then had a wrecker winch it over until it was in the right spot.
Containers, truck beds,bus/mobile home frames make excellent bridges.
RD
/ Cheap Bridge idea #11
I remember as a kid, people would get a railroad flatcar and use it for a bridge. However I think finding one, and getting it in place would be a major challenge, and more expensive than building one in place.
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A65563)
2011 Ford F-350...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
2012 CARGO CRAFT 24' T/A ENCLOSED TRAILER (A65643)
2012 CARGO CRAFT...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
