Cherry Tree Log worth anything?
   / Cherry Tree Log worth anything? #1
JasonL
Pendleton, IN
JD 4110
What size logs are worth something to someone?
I am clearing land for a barn and will be removing 5-6 cherry trees.
They are fairly straight and about 10"-14" diameter.
Do you think someone would ghive me something for them or should I just cut them up for firewood.
I would love to have a portable sawmill and cut them up myself, but then I'd also have to find someone with a kiln to dry them. I can't afford to spend any money now.
Any thoughts? (Also, if they are worth something, how to find someone who wants them?)
Thanks Jason
Thanks Jason
   / Cherry Tree Log worth anything? #3
My gut tells me they are worth $$$$$$$$$$$$$.
Call a local word worker, fine furniture builder and see what they say. don't cut them down or do anyting until you know.
Bob
   / Cherry Tree Log worth anything? #4
Bob
   / Cherry Tree Log worth anything? #5
There are some old posts regarding the value of lumber- you may try a search. For the quantity you have I doubt that a commercial operation would be interested. BUT, as a woodworker I would be very interested. I would ask around, there should be a portable sawmill operator that could help you out. If you can use the wood you could have them milled for now, stack them so they air dry and don't warp, then have the lumber down the road. Around here it would cost around $50 ro $75 to have them milled.
If the logs are of high enough quality you may have luck selling them for veneer. I'd call a local forester and ask.
Good luck
   / Cherry Tree Log worth anything? #6
Good luck
   / Cherry Tree Log worth anything? #7
In general saw mills require logs to be at least 12" on the small end for them to have any interest. You may find someone with a portable sawmill who can cut them up for you but keep in mind that the desirable wood in cherry is the hartwood, the outside 3 or so inches is still white and does not have the desired color, so you won't get much usable wook.
I usually sell my cherry when they reach 22 to 24 inches at 4 feet above the ground.
   / Cherry Tree Log worth anything? #8
   / Cherry Tree Log worth anything? #9
Last weekend I used a chainsaw mill to cut up cherry tree [ 20"x8' ]. There are still some cherry logs to go that are smaller. Some of the slabs that were and will be cut come from pieces that a mill could not handle and will have natural curves in them.
Kiln dried is not required but properly stacked dry storage is a good idea.
The trees should be worth money. How much is ???
Egon /forums/images/graemlins/grin.gif
   / Cherry Tree Log worth anything? #10
   / Cherry Tree Log worth anything? #11
Cherry wood is almost always worth something more than fire wood. If the trees are growing around houses or fence lines many sawmills do not want them because of he danger of metal, nails and other such items, in the wood.
Most areas have a county forester or Extension service who can give you names of log buyers. There are usually publications for your area posting the range of prices paid for different species of wood that a local forester can direct you to.
You can place an add in the paper, many woodworkers are looking for cherry wood for turning and furniture purposes.
You many not get rich off these logs but don't under estimate the value either.
You can air dry the wood yourself should you decide to have it milled into lumber. Cherry dries pretty good if "stuck" correctly in a dry location.
I have a portable sawmill and have milled out quite a bit of cherry and made some nice cabinites and other furniture items out of it.
Randy
   / Cherry Tree Log worth anything? #12
Randy
   / Cherry Tree Log worth anything? #13
Mornin Jason,
To the right person those logs are worth some money. Cherry is a beautiful wood and one of my favorites !As others have said, find a local sawyer and get those logs sawed up and sticker them properly to dry. Around here, cherry that is dried is going somewhere around $5 per board foot. After you get it dried, advertise in a local paper. If I was in your area I would be very interested. I built this entertainment cabinet out of cherry and walnut a few years ago, and enjoy it all the time /forums/images/graemlins/grin.gif Entertainment Cabinet
   / Cherry Tree Log worth anything? #14
Mornin Jason,
   / Cherry Tree Log worth anything? #15
Years ago the remnants of Hurricane Floyd hit our hillside and I lost over 300 hardwood trees, mostly maple (both soft and rock) and black cherry. I hired a portable mill owner and had it converted to lumber at .15 a board foot. It was carefully end sealed, stickered and air dried in the garage with a considerable amount of weight on top. I ended up with 1800bf of 5/4 cherry and the same amount of veneer quality rock maple. Still have all the maple since my wife insists on piling her crap in front of it so I can't reach the lumber, but have used most of the cherry. It's a dream to work with!
Pete
PS: Any locals interested in some 8/4 clear rock maple boards 8 feet long and up to 11" wide, drop me a PM.
   / Cherry Tree Log worth anything? #16
Pete
   / Cherry Tree Log worth anything? #17
Cherry is also great for smoking meats.
   / Cherry Tree Log worth anything? #18
   / Cherry Tree Log worth anything? #19
Call your local State or District Forestry Dept and ask for information either from a Forester or a recommendation for a business with Consulting Foresters. You will get the parameters that you will need to move forward on a decision. The trees you mention are on the small size, but that doesn't mean they don't have value. Will depend on your interest in just selling logs, or getting lumber from the logs to either keep or sell.
Lots of ifs, ands, and buts to consider.
A forester can answer them for you.
Go to the ForestryForum.com and pose that question, as well as look for nearby sawmills that may be interested in the logs or be able to saw them for you to get the lumber.
   / Cherry Tree Log worth anything? #20
1985 John Deere 540B Skidder (A56438)
1985 John Deere...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
LEEBOY 8530 ASPHALT PAVER (A60429)
LEEBOY 8530...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
iDrive TDS-2010H...
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
