Bill_C
I don't use cutting oil. Maybe it would extend the life of the blade, but the extra mess for me isn't worth the aggravation...
canoetrpr said:Bill_C. Thanks for the tip. I checked the manual on HF and sure enough it is the exact same bandsaw that I got from Princess Auto here. The HF manual is AWESOME! I now know what the point of some of the parts - like the stock stop
One question: Should I be using cutting oil at all when operating it?
canoetrpr said:Yep, this one did come with the stamped metal thingy to convert it to a vertical.
I spoke too soon on the blade. On the third or fourth cut, the blade snapped. Right at the spot where it had been welded together from the factory.
I took it back to Princess Auto. They have awesome after sales service. Dosen't hurt that the girl at the customer service desk is kind on the eyes as well. She replaced the blade for me with a bimetal one. I offerred to pay the extra amount but since I was inconvenienced they sucked up the extra $10 or so. I picked up a replacement one as well just in case I loose another one when they are closed some time.
Now its probably not a quality bimetal blade... but it is bimetal and I have done several cuts today and its worked well. The bandsaw still requires some TLC between cuts - check blade tension etc. etc. but is working out quite well.
Will check on the 4x4 links. Replacing the gear lube seems like a great idea. I have decent stuff lying around anyway.
bjr said:I have reconditioned "D" handle style Dewalt chop saw that's been great for 4 yrs. It's been intermittened light duty use. Now when I try to start it, it pops a twenty amp circuit breaker. I've switched breakers and it does the same thing. after trying it about 6 or 7 times it will finally take off without popping the breaker. Is there a autobrake on the amutuer or some to stop the wheel? I don't know what's going on? Does anyone else have this issue with a chop saw? bjr
Egon said:Buy a blade welding kit and some good blade stock.![]()
