Choosing just one grease..
   / Choosing just one grease.. #141
If you have not used it, I'd return it. Get literally anything else. Lucas red and tacky, Mystik JT-6, Gladus S2 (on sale for a whopping $3.24 at TSC). Reason is lucas green is polyrurea based, and is not compatible with pretty much any other grease. You can use the other ones and just switch to Amsoil whenever, no issues with compatibility (although I like to pump out the old grease for good measure when switching).
Grease Compatibility Chart and Reference Guide
So your biggest reason NOT to use Lucas green is incompatibility with other greases?
If starting new with Lucas green, its ok, though?
   / Choosing just one grease.. #142
Yes, it's ok to start and stick with. But if memory serves there are better choices.
The incompatibility is only an issue if Lucas Green is Polyurea Conventional grease. If it is polyurea shear stable, it is much more compatible with other greases, almost a non-issue. I just don't know which one it is, so I stay away. Lucas can probably answer that for you. Shame it's not on their TechDataSheet.
   / Choosing just one grease.. #143
Many references online recommend the Air Tec Lube Shuttle grease gun and the screw-in, no-mess containers.
How do these grease offerings compare to the others in this thread, such as Amsoil Synthetic Multi-Purpose #2 ?
Li400 Extreme Duty Grease - Lithium Complex
Li4?? Extreme Use Grease - The Lube Shuttle
KH150 Full Synthetic - Calcium
KH15? Full-Synthetic Grease- Lube Shuttle
Misc summary pages:
Air-Tec Grease for Lube-Shuttle(R) - The Lube Shuttle
As with the WD-40 grease offerings, Air Tec doesn't list as many technical data points online compared to some other manufacturers that specialize in petroleum products.
   / Choosing just one grease.. #144
Misc summary pages:
The answer is most of their non-moly grease offerings do not compare well. I understand your enthusiasm for the Lube Shuttle, it's a great piece of kit, but I was put off by the lack of available grease choices. In the end I bought a pneumatic grease tub, that filled from a 5 gallon pail.
If you don't mind the staining power of moly, then you can get Paragon 3000 for the lube shuttle. Best in class moly grease, for the real heavy duty users (lots of shock load, lots of mud etc.).
Paragon 3 Lithium Grease Lube-Shuttle(R) - LOCKNLUBE
   / Choosing just one grease.. #145
Bought the kit and greased the tractor today. No mess whatsoever from start to finish!
The price is a premium compared to commodity grease and a traditional grease gun, but nothing makes frequent greasing easier with a portable grease gun.
Lube Shuttle Grease Gun (Store - AET Systems, Inc.)
NPT thread adapter (Amazon.com: Metric 1x1 (f) to 1/8" NPT (m) adapter: Home Improvement)
Lock-n-Lube swivel (Amazon.com: LockNLube Grease Gun Hose Swivel - Rated to 1, PSI, works with any grease gun: Home Improvement)
Lock-n-Lube connector (LockNLube(R) Grease Coupler | LockNLube(R) - LOCKNLUBE)
TRC Paragon 3000 grease in screw-in tube for the Lube Shuttle from Lock-n-Lube (Paragon 3 Lithium Grease Lube-Shuttle(R) - LOCKNLUBE)
   / Choosing just one grease.. #147
Guess someone re-invented the wheel, kind of an expensive wheel though, and once a person buys this wheel looks like he's stuck with this wheel cause it looks like that wheel only works with one kind of wheel.......... Lube-Shuttle(R): Electric Grease Gun (2 batteries) - AET Systems, Inc.
Easiest Grease Tube Change - YouTube
The battery powered gun is way overpriced, and a one trick pony (I don't need another battery type in my garage). Quick note we may see some clones that accept the same screw in cartridges soon, as it is a standard in Europe. I have seen a 'reasonably priced" pneumatic version that should be on its way also.
For heavy users, they do sell a bulk pump adapter and empty tubes. That way you can fill your own screw on tubes with your own grease.
   / Choosing just one grease.. #148
The pistol grip and lever action Lube Shuttle grease guns are approximately $60~$70 delivered.
Compare to other name-brand grease guns, such as from Lincoln. The Lincoln pistol grip grease gun on Amazon is ~$40, but uses the traditional design with the follower-rod, handle, spring, etc.
Other brands and models show anywhere from ~$15 to $50 for traditional design grease guns.
The Lube Shuttle introduces a new design, which does away with the follower-rod and other components below the tube.
I viewed the Lube Shuttle grease guns as a +$30 premium over traditional design options, and the screw-in grease tubes aren't much more than traditional tubes, although the variety is limited, unless you fill your own tubes and buy the empty screw-in containers, as Mangler describes above using the bulk pump adapter. Note, the screw-in tubes are reusable, unlike most traditional grease tube refills.
$15 for TRC Paragon 3000 in screw-in tube from Lock-n-Lube when bought individually (buy two or more for free shipping, and discounts kick in when buying a box of 10 or more). Paragon 3000 is about the same price in a traditional tube.
Agreed, the Lube Shuttle model that is an electric grease gun is expensive, but a battery-powered grease gun from any company is going to be expensive. Lincoln makes one for ~$330, and it uses the traditional design with follower-rod.
Linked below is an image of the pistol grip Lube Shuttle with Lock-n-Lube attached (plus swivel and NPT adapter), and a tube of Paragon 3000 grease in the screw-in tube.
   / Choosing just one grease.. #149
"(I don't need another battery type in my garage). "<<<<<<Amen to that!!!!!!!!!!!!!!!
   / Choosing just one grease.. #150
   / Choosing just one grease.. #151
I agree, the 30$ premium is really worth it not to have grease oil drip all over your shoes next time you grab the gun...If you don't mind pistol grip, and you like the Paragon grease, that Lube Shuttle combo is unbeatable for usability and value IMHO.
It is really too bad they don't partner with a known tool manufacturer and offer a bare battery tool that uses their standard battery. Couple that with a good grease partner (Amsoil, Shaeffer, even Citgo) to provide good grease in the screw on tubes, their market share would explode.
   / Choosing just one grease.. #152
Mobilux EP2 grease. $47/box of 10 on Amazon. It's one of the recommended greases for the Kubota KX040 mini ex which will certainly meet the needs of any loader pins.
I use the red traveler grease from TS for wheel bearings in a separate grease gun.
   / Choosing just one grease.. #153
The Mobilux EP2 is just OK. i certainly would not pay more than $4.70 a tube for it. TDS is weak, no water washout spec, weld point is quite low at 250kgf. There are better choices out there. I certainly would not use it on my mini ex, IF I owned one :)
   / Choosing just one grease.. #154
Humm, well this is one of the recommended greases to use right out of the operator's manual. I try not to overthink what the manufacturer's engineers recommend. Here's what the Mobil site lists for this grease:
"Mobilux EP 0, 1, 2 and 3 greases are recommended for most types of industrial applications including heavy-duty applications where high unit pressures
or shock loads are present. These greases provide excellent protection against rust and corrosion and resist water wash-out which makes them
particularly suitable for equipment where moist or wet conditions are common."
I know the usual reply is "use what you want, it's your machine...", but I challenge anyone to point out a failure resulting from using the manufacturer's recommended oils/greases, etc. If you can, I bet it's an extreme rarity.
HP
   / Choosing just one grease.. #155
HP
Indeed, it is your machine. This basically has General Purpose (GP) grease specs. So it's just that, general purpose. You can get 2$ a tube grease with similar specs. If you like greasing your mini-ex, I'm sure it would not be the source of failure. Mini ex loads are usually quite low, considering. But there are way better greases out there. Lithium base can also be a problem if you want to switch it out later by the way, not the most compatible.
(10) 10'-6" PVC CONDUIT PIPES (A60432)
(10) 10'-6" PVC...
2373 (A60432)
2373 (A60432)
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
(2) UNUSED FUTURE 10' SLIP-ON FORK EXTENSIONS (A60432)
(2) UNUSED FUTURE...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
UNUSED RAYTREE RMLS18T-18 TON HYD LOG SPLITTER (A60432)
UNUSED RAYTREE...
