Choosing the right tractor
   / Choosing the right tractor #1
Mej13579
Bronze Member
None
I have 25 acres in East Texas. I am looking for a new tractor. I have about 5 acres to mow. Sometimes in the spring it rains a lot and by the time the field dries the grass gets 2-3 feet tall. My zero turn mower is getting beat up pretty bad.
I have mostly woods but I tried to put trails in but a 4 wheeler , chainsaw and weed eater just isn't cutting it and I can't keep them from getting overgrown.
I also had my plantation pine thinned and I need a lot of clean up. I have a mixture of pine and hardwoods. I have some huge oaks down but can't get to them with what I have now. Got about 300 yards of driveway that needs some work. I have a pond that needs cleaned up around the edges and cleaned out when it gets low. Plus some general dirt work and such.
I am looking for an all around workhorse in around the 50hp range still nimble enough to navigate in the woods.
The 3 tractors I'm seriously considering to aquire in about 2 months are the massey ferguson 2850e, kioti dk45se, or the kubota l4701. I'm looking to get a grapple / 3rd function, a mid range rotary cutter, boxblade, and if I can swing it a tiller. Looking to make a long term investment. To get it paid off before I retire in 6 years or sow.
My credit is not great but should have a large down payment almost half.
Any suggestions on what I should be looking at.
   / Choosing the right tractor #2
I'm in a similar situation... Closer to 20 acres...were between I20 and I30 about an hour west of LA.
I would consider widening your search. TYM, LS and Branson all have dealers in the area and can possibly get you more tractor for the money. For the same price the TYM and Branson will have considerably more weight and lift capacity. There's a dealer in Longview that has both Kioti and TYM, so you can compare. Dealer in Tyler has LS, TYM and Zetor. There's a big Branson dealer in Caddo Mills. Many LS and TYM models come standard with rear remotes and 3 PT hitch lever in back, also have the nicer adjustment arms instead of turn buckles.
Thank you. I'll check them out also. I know there is a branson dealer in carthage
I'm in between marshall and texarkana
   / Choosing the right tractor #5
Welcome to TBN...enjoy.
Thier been many threads on this topic try search,just some of question to consider.
Have you visit dealers yet?
Have you consider cab?
What type of transmission?
What type of tire thread?
   / Choosing the right tractor #6
We are near FtW, but retiring this summer to our land further east. Technically, Carthage is closer, but the dealer in CM comes highly recommended.
In your range, maybe a TYM 494, an LS 345, a Branson 4820.
No I haven't visited any dealers yet.
I do not want a cab due to a lot of work in the woods.
I'm considering a hydro bit I think I could make due with a shuttle shift.
I am leaning toward ag tires.
Thanks Torvy. I will check them out. I'm sure you will enjoy the move. Got transferred out here about 10 years ago from Dallas and love it.
   / Choosing the right tractor #9
I would think an industrial type tire would be better than an ag tire in the woods and, in general, for what work you describe, except, possibly the tiller. The radials seem to be quite popular.
O personal experience with the ag tires, just going by what I see and what my dealer told me.
You might be right Finn.
   / Choosing the right tractor #11
My initial reaction you are looking on the large size of what you need but it seems people often start out to small so I’d say your in the ball park. Of the ones you listed I like the Kubota best but the Kioti looks attractive also. I’d throw JD in the mix also if there is a dealer nearby.
   / Choosing the right tractor #12
The 3 tractors I'm seriously considering are the massey ferguson 2850e, kioti dk45se, or the kubota l4701
I have a pond that needs cleaned up around the edges and cleaning when it gets low.
The significantly larger wheels and tires which come on a Kubota MX series tractor should be considered.
Cat I/II Three Point Hitch standard on Kubota MX series tractor is much more robust than Cat I (only) Three Point Hitch on a Kubota l4701.
   / Choosing the right tractor #13
Kubota MX5400 or 6000, open station. Check them out.
   / Choosing the right tractor #15
OP. . . The TBN Member “Tradosaurus” is in your neck of the woods. I’m sure he’ll post on here soon. He might give you some good advice on dealers in the area. He and I have an MX5400. I thought the L4701 would be the right size of me, but I went one step up just to make sure.
   / Choosing the right tractor #16
I thought the L4701 would be the right size for me, but I went one step up just to make sure.
I thought the L4701 would be the right (size) weight for me, but I went up one increment in weight just to make sure.
Tractor capability is more closely correlated to tractor weight than any other specification.
   / Choosing the right tractor #17
My gut says Kubota MX with beefy industrial tires…..
Thank you for all your post so far. I like the MX 5400. That's a great choice. The two things is size and price of the mx. How much more price is it over a l4701? Is the mx gonna be nimble enough in the woods for cutting trails and logging and with all the implements I need with it will it be out of my price range?
Checked out the branson dealer online and he looks like a good place to start. You were right about being worth the drive.
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
