Circular paver driveway
   / Circular paver driveway #121
Don, you and Ron are quite the team. That finished section with the drain looks great. I hope you have enough pavers to make it all the way. I'm surprised that Acme didn't at least try to come up with a solution. How about Pavestone? Do they have anything even remotely close in color and size?
   / Circular paver driveway #122
Robert I called Acme today they said the 10,000 pavers I bought from them 3 years ago were the last of the inventory of those pavers from all their different locations. With the economy the way it was they shut down 8 plants. They have no more and cannot make anymore.
Perhaps finalizing/modifying the plan should come sooner rather than later.
Regardless of how well you protect the layed pavers, there will be some that become damaged or discolored over time. What I am suggesting is that you hold some of your existing inventory back for future repairs.
That gives you the best chance of making a repair that isn't an ugly looking
patch that sticks out like a sore thumb. Even then, if you don't seal the ones that are layed while they are new, and make a sealed " take up reserve patio"
behind the barn somewhere that is exposed to the elements of the spares, you won't get an unobserveable blend.
You might be able to find another company that makes pavers super close in color, size, shape and texture, but I kinda like Dennis's idea of designing a family crest, if your family doesn't all ready have one that you can copy.
When I first mentioned sealing you countered with something like, " this is a working farm, so we don't worry about some stains."
All the blood, sweat, tears, and sore knees, to get the great looking finished project, has made it much more valuable in your mind, as it should...
I'd be letting the air out of Ron Hall's tires and feeding him anything he wants to keep him around to help a little longer:)
here is a good picture of where we are.
You can see the beginning of section 1 and the end of section 4.
I have enough pavers for only 3/4 of the remaining curbed in area.
The other picture is the stack of pavers I have left.
A decision will have to be made shortly on which stretching method to use and have it not look like a stretching method.:D
   / Circular paver driveway #124
You could get a dark paver and make two Big arrows showing the direction of travel,
or as you are filling it in start to put in a fade, where you use pavers of different colors to transition to a different color.
   / Circular paver driveway #125
I just need to come up with some type of design. I'll take a picture of the area of concern, so you can see the shape we have to work with and post it later. If I go with mosaics, I'm thinking more in the lines of nature (animals, trees) or farming (tractor), the theme of this rural Texas area, or a large Texas design.
Another option would be cement in the middle with a sidewalk wide boarder of pavers, on the last outside parts of the Q that nicely tie everything together.
Thank you for your ideas.
I would stay with either a "Texas" theme, or a "wildlife" theme, only because of resale later, a bit more ambidextrous.
What I highlighted in Red, makes perfect since, clean but similar, add a 2-3' Texas shape in the center, maybe in Gold or Silver color, that would look nice! If a Brass medallion was a possibility, that would look awesome.
   / Circular paver driveway #126
I would take 2 or 3 of your pavers to some stores, including HD & Lowe's, & see if they have anything close to matching, & if they do, buy enough, bring them home & randomly mix them in with your remaining originals so they blend in as much as possible.
   / Circular paver driveway #127
A couple of pics from the sidewalk lay.
The driveway pavers are on the porch at the bottom part of the last photo.
How many pavers did you use on the sidewalk? Can you pull them to get enough to finish the driveway and then put a different color or style in for the sidewalk?
I'm very nervous about a pattern or something artsy to make up the difference. They either come out amazing, or incredibly odd looking. Sadly, most of the time, it's pretty bad.
While ACME has told you that there are no more pavers, and I have no reason to not believe them, have you called each store individually to see if this is true? Or to see if they have sold to places with some inventory?
I had a job a couple of years ago requiring a Mexican Adobe brick. They where a lite tan shade that had to be just right for the job. I needed 2,000 bricks and was only able to find 500 locally. The people at ACME Brick here in Tyler gave me a list of brick suppliers in the DFW area that might have more. I called a dozen of them and half of them said that they might have what I wanted in their yard, but I would have to come and see for myslef. I was able to find the remaining 1,500 bricks in three different yards. It took a full day, and I paid a bit more for them then there then I did in Tyler, plus burning gas, but that's just part of what it takes sometimes.
Eddie
   / Circular paver driveway #128
Well that's a bummer. I've been bit like that before. It's a main reason I always try to buy all the materials I will need at once. Now if I could only make myself buy enough EXTRA at the same time so I have spares, cover problems/things I forgot/broken parts/etc...
But it sure is looking really nice!
Today we finished section 4. YEA!
We hand tamped the pavers, recheck all the spaces, elevation and replaced a few that cracked. We then poured polymer sand and swept it in the spaces, hand tamped it all again to set the sand and re-swept it and then misted it.
Eddie
Eddie the sidewalk pavers are different and not rated for vehicle traffic. The ones by the front porch and the side porch are the driveway pavers but will not be removed.
beepington, will do. Last time I checked they were not rated for vehicle traffic, but that was a few years ago.
I'll check a few different sources like you did to see what I can find.
On to section 5 solo again, It was fast and fun for short time, Thanks Ron!
2022 John Deere 9RX 640 Track Tractor (A53485)
2022 John Deere...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
PALLET OF 2" X 4" STEEL TUBING & SITE PANELS (A54757)
PALLET OF 2" X 4"...
