Cistern Water Level Gauge
   / Cistern Water Level Gauge #11
Realgoods.com is an alternate energy supplier. They sell float switches usually used to turn a pump on/off to keep a cistern full. Perhaps you could wire one to a light so the light turns on when the water level is low.
This link will take you to the float switch page
<A target="_blank" HREF=http://www.realgoods.com/renew/shop/product.cfm?dp=1900&sd=1907&ts=1041637>http://www.realgoods.com/renew/shop/product.cfm?dp=1900&sd=1907&ts=1041637</A>
Phil
   / Cistern Water Level Gauge #12
Just looked at Realgoods "water" page. They have something called "The Ginny" which is a guage for fuel tanks and water cisterns. No picture but here is the link.
<A target="_blank" HREF=http://www.realgoods.com/renew/shop/product.cfm?dp=1900&sd=1907&ts=3653210>http://www.realgoods.com/renew/shop/product.cfm?dp=1900&sd=1907&ts=3653210</A>
Phil
Thanks for the suggestion. I was trying to think of a source of a small air pump but hadn't thought of a fish tank aeretor pump. That should work. There are lots of low water level warning systems available but I was wanting more than that. Now the challenge is to find an appropriate air pressure guage.
   / Cistern Water Level Gauge #14
Or if you don't mind doing the math 2.31ft of water = 1 psi.
And that's the problem in finding a reasonable guage because my cistern is only 8 feet deep, so I have a max pressure of about 3 psi.
   / Cistern Water Level Gauge #16
Do you have access to a Grainger store. If so part #'s 2C632 or 5XP57 will get you one up to 100". I believe they are 1 and 2 " increments.
Thanks wichiwichi. I found the mfgs part nos on Graingers website so now I can pick one up locally.
Thanks again.
   / Cistern Water Level Gauge #18
A friend of mine in Fort St. John has a similar issue with his water supply. I was able to assemble for him a level indicator for about $120.00 bucks. It works on the principle of water conductivity and operates on a 9v battery . While it doesn't tell you exactly how much water you have, indicator lights will tell you that you have less than 30, 60, 90 and 120 inches of water. I can actually wire it to give readings in whatever graduations you like. All that is needed is to toss the sensor into the cistern with a weight attached to it so that it makes it to the bottom of the tank. To check the level he just pushes a button on the indicator. The most expensive part was the wire. He is using about 70 ft so he was able to bring the unit indoors.:)
   / Cistern Water Level Gauge #19
why not a string on a bobber with a fishing weight attached on the other end, run through a pulley.
   / Cistern Water Level Gauge #20
Might want to use a chunk of copper instead. Fishing weights are usually made of lead which is toxic.
Dave G:)
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2022 John Deere R4023 (A60462)
2022 John Deere...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
