Ck weird electrical.
   / Ck weird electrical. #1
pickeringchris
My CK27 has 80 hours and has run flawlessly for the year and a half I've had it. I just noticed 2 weird electrical things.
1) headlight switch. In the off position the lights are on. Key or no key. In position 1 they are off and in position 2 they are on.
2) glow plug light does not go out after 8 second. It will stay on for 60 seconds if I leave it.
Any thoughts would be appreciated.
   / Ck weird electrical. #2
glow plug would be your timer relay. light problem is weird.
Ya the headlight thing is a mystery. I put the tractor away and the next morning it wouldn't start. I charged the battery and as it charged the headlights went on. It was clear at that point, the headlights being on was what caused the battery to die. I immediately checked the switch and it was in the off position. I turned it to position 1 and the lights went off. Position 2, they went back on. After charging I went to start and noticed the glow plug light wouldn't turn off. The timing clearly indicates the 2 problems are related.
   / Ck weird electrical. #4
Ghost in the machine. Do you have a Service manual? I have one but its for the DK series.
   / Ck weird electrical. #5
Chris my first thought is water/corrosion in a connector somewhere. Any chance of that? A service manual is a must for this.
Yes I have a service manual. Not that I can understand it. I will probably contact my dealer since its still under warrenty.
The tractor is always stored in a heated garage. I did wash it a couple weeks ago. Any source of water would have had to come from washing it. Is that enough to corrode something?
I have the manual opened on electrical system. I think I got the wrong manual. It's written in Chinese or something. Lol
   / Ck weird electrical. #9
Only thing I can think of is maybe water accidently got sprayed on one of the connectors, and started corrosion or something, but I could be way off base here too. I wonder how close the electrical schematic is to my DK. I take it you are not used to reading electrical schematics.?
Is this what you need James?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Pintle Hitch Triple Axle Trailer - NO TITLE (A59814)
Pintle Hitch...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2002 International 9200i Truck (A56438)
2002 International...
