clearing sapplings
   / clearing sapplings #11
Here's a link to their website: www.brushbrute.com
They're kind of pricey, I'm sure that is one reason why TraderMark made his own.
   / clearing sapplings #12
A heavy duty rotary cutter worked for me, even on locust saplings. I used a 'crawfish' approach, backing up and slowly lowering rotary cutter into saplings, privet, etc. and mulched away.
If you go this route, wear hard hat, safety glasses, and ear plugs. A thick piece of plexy or wire mesh added to the back of your ROPS, or safety chains on the front of the rotary, are good ideas too. /forums/images/graemlins/grin.gif
   / clearing sapplings #13
You need a brush shredder. They make them as attachments to either skidsteers or on the 3 pt of the tractor. It is a rotating drum that grinds the material down to nothing. If all you have is 1-3" diameter undergrowth on relatively smooth ground then I would rent the SSL and brush shredder. The machine looks like it moves through relatively quickly. Within a few days the brush would be mulch on the ground. Then a nice heavy disc.
I have heard that if you can run it over, the rotary brush hog will chew it up. The big FEL will allow you to lay down the saplings before mowing them. On the larger ones that don't lay down you can jump out and chainsaw them close to the ground.
If you avoid pulling the stumps then the amount of material do get rid of drops substantially.
I have the same type of sapling/brush problem but I have a small dozer to do the knock down.
   / clearing sapplings #14
A HD cutter will work quickest and you'll have an implement that is still useful after it's all done. You might have some resprouts, but continued cutting will destroy them. I've cleared over 10a of 3-4" saplings with my cutter and keep it cut regularly with same tool. My .02.
   / clearing sapplings #15
I don't cut 'em if I'm going to use the tractor to clear 'em, I don't like leaving stumps. They have a tendency to be a pain if you decide to work the dirt or dig a trench at a later date. The tree helps lever the stump out of the ground if it is more than the loader can handle. I dig down in front of the root ball, working the bucket roll and dump to cut roots. Then I raise the loader as high up the tree as I can and reef on the tree. Make sure the tree isn't rotten, you don't want it to snap and come back on you. If it doesn't go I dig down into the root ball some more. The guy I had helping me the last time I cleared some dirt told me the tractor had the front end so far down in the hole that it looked like a terrier digging for a rat. I was digging out 12" to 14" diameter trees at the time. Once it starts to go you have quit pushing and back up and get another bite on the tree, you can roll the root ball up under the tractor. I've done that without any damage but you never know what you might destroy. It could lift the front end enough to dig the box scraper into the ground and then you are stuck. I got to backing out of the hole and filling it with dirt once the root ball was cut loose and the tree was ready to come down, that lets the loader hit higher up on the tree. I did blow a steel loader line while doing this once, but I went right back to the same tree and finished the job once I got the tractor back and the second line held. It must have been a bad part. /forums/images/graemlins/smirk.gif
   / clearing sapplings #16
A toothbar will pop them right out of the ground.
   / clearing sapplings #17
Sounds like he's clearing a thicket. Clearing 10a of 1-3" saplings with fel would really take some time. I used fel to pile up what diddnt get completely pulverized by cutter and burned whole mess. Stumps that size rots in no time and aren't reallymuch of a disc or trench problem. I guess it depends how much seat time you can afford.
BGott and MMM,
yeah, i am clearing thicket, very dense. the challenge is that i want to work the soil, so i don't want alot of stumps or trash left behind. also trying to make the smallest impact on the top soil. maybe cut them and rent a harley rake. never used one so not sure it would work in this application.
paul
   / clearing sapplings #19
Paul,
I was cruising when i came I came across your post and you asked "what are yopon"? If it's still any interest, yaupon are a type of holly, native to the southern states. They are tough and hardy.
Clem
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
John Deere 60 Tractor (A59814)
John Deere 60...
2002 Bobcat 763 Compact Skid Steer (A56438)
2002 Bobcat 763...
Deere 310L (A53317)
Deere 310L (A53317)
John Deere 980 Field Cultivator (A59814)
John Deere 980...
