Clipper belt lacing tool and clips help?
   / Clipper belt lacing tool and clips help? #1
Horseshoe Bend, AR
Farmall Super M Mahindra 6110
I have a New Holland 4x4 round baler that needs new belt ends put on once in a whole, usually when I have a half a filed left to roll up and a cloud is coming in! I usually have an hour or two in down time to run to my belt guy and have a new end laced on. My splices have a 3/32" connector wire for the splice.
This year I want to get my own set up to keep the down time to a minimum. My belt guy uses the clipper system in a vise. How to use it is easy enough to figure out. There are 7" long clipper splicers on eBay for around a hundred bucks. The actual clip size is what I'm stumped on. What part. Umber or size do you fellas use for the clips? Can I run any clipper style hooks through the clipper head? Or is there a certain model clipper head for specific clipper hooks??
Needing to know pretty soon as hay is looking really good right now!!
Thanks fellas!!
   / Clipper belt lacing tool and clips help? #2
You can look in your baler info, it probably will specify what size clips to use.
Just make sure you have a good vise, I stripped one out. Or get the lever style press made for the clipper style lacers
   / Clipper belt lacing tool and clips help? #3
   / Clipper belt lacing tool and clips help? #4
Go to Conveyor Belt Fasteners, Cleaners, Trackers, and Accessories - Flexco there you will see the different tools that are used with the fastening system. Most of them are not real user friendly for us novice belt lacing people. Their system works really well and normally last very well. Thinking that I would keep a spare belt or 2 and have a professional re lace the old belts for spares. I sell the lacing and the tools but do not repair the belts
   / Clipper belt lacing tool and clips help? #5
Not sure what type of lacer you are dealing with, but typically a lacer has different "heads" that will accept different size laces. What size laces you use really dont matter as long as both ends of the belt are the same.
Somewhere in the garage I have an old clipper no9 lacer with a few different jaws. looks like this one Clipper 9 Belt Lacer | eBay
If that may be something that interest you, I have no use for it. Send me a PM maybe we can work out a deal.
   / Clipper belt lacing tool and clips help? #6
Or you can just keep an extra belt on hand and have your belt guy continue to lace them.
   / Clipper belt lacing tool and clips help? #7
I do my own also. Broke my first vise which I thought was a very sturdy 6in. New vise is a 8in. machinist vise. Works a lot better.
   / Clipper belt lacing tool and clips help? #8
They really aren't that hard to do, I'm not sure why everyone is so leery of doing them. Takes about 10 min. There are portable presses for doing them in the field as well
   / Clipper belt lacing tool and clips help? #9
I have one for 4x4 NH 630, came with the baler, 6" unit for a 7" belt....nice... but it works better than nothing and has saved the day a few times.
I will have all brand new belts for this season. Nothing like the factory tight laces. $135 each free delivery in USA....
   / Clipper belt lacing tool and clips help? #10
I'll agree with them being hard on a vise, broke two, fixing one belt. Didn't have the press moved here from the other place yet, so that's all I had. Hydraulic press is definitely the tool to use with one!! A hydraulic vise would be sweet, but can't justify the cost.
2018 Kubota U17 (A53317)
2018 Kubota U17...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A59905)
2015 UTILITY VS2RA...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
iDrive TDS-2010H...
Kubota M5-111 (A53317)
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
