Dead simple (provided you have unrestricted access to the inspection port). But I misspoke earlier, inadvertently identifying the zerk behind the round black plug with the grease point on the TOB. Sorry bout that.
Anyway. Remove louvered cover, reach in, rotate bearing by hand until you can see the little hole. Little bitty thing - only 2mm diameter - easy to miss on a dirty bearing. Stick the needle tipped grease gun into the little hole, squeeze.
The weakness in this design, is you're only filling one side. So I pump a time or two till it pukes, then rotate the case in hopes of rolling some dry bearings behind the hold. I do this several times, and hope for the best.
A simple sealed bearing would negate the whole requirement, and probably have saved us all this consternation. But I guess nobody makes a suitable sealed replacement. Short of that, this is the time for Rob to really really really really pack the new bearing well before installation and reassembly. I actually overpacked the last one. For a few days it didn't rotate well after a cold start - until friction thinned out the grease. Noisy, but fortunately short lived. And given the fact that you can only pack these things when the tractor is split, I think it's safe to say that a little too much grease is better than not enough
//greg//
