greg_g
Super Member
- Joined
- Dec 18, 2003
- Messages
- 6,126
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
It would be a waste of machining time Rob. Wait until either you get the old clutchpack on the bench, or until a new one arrives - whichever occurs first. You'll quickly see what I mean. Bolting in the clutchpack doesn't compress anything other than holding the PTO friction disc against the flywheel. It's adjusting the stack height that puts tension on the Belleville springs. And - for me - that's most easily done on the bench, with a piece of plywood simulating the flywheel surface (for measurement purposes only).
There are six nuts to adjust; three for the main drive pressure plate, three release fingers. First thing to do is insert the flywheel bolts to line up the holes. Then gap the main drive first, adjust the fingers last. When the stack height is to spec, the fingers are supposed to be on a level plane. Replace pilot bearing. Install clutchpack on tractor. Verify stack height. Replace TOB (and seat if necessary). Reassemble tractor. Adjust clutch linkages. Go back to work. The only way this particular pooch can be screwed, is if there's an indentation for the PTO disc on your flywheel fact. If you encounter that, it's still a simple matter of a few correcting turns on the 3 finger nuts.
Oh, there are three external linkage adjustments by the way; (1) neutral gap between fingers and TOB face, (2) pedal play, (3) pedal stop
//greg//
//greg//
