Color code of JD implements?
   / Color code of JD implements? #1
nomad
Platinum Member
TR
MH744
JD fanatics/enthuatists, I have a question. The green of JD tractor is different than the green of JD implements, isn't it? I think I am a colorblind a little because I can't see the minor differences between the colors. If there is difference, I need RAL code of JD implement green (also ral# of JD tractor green, to compare the colors on the net.) I am unable to find RAL# of greens of JD tractor/implements. I can (maybe) find other color codes like Dupont, etc - but my need is ral as this color tech. is mostly used here. Okay, help me and your dinner & wine bottle this evening are on me.
   / Color code of JD implements? #2
Converting some implements and tractors over to JD??? Need Decals too???
/forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
Egon
</font><font color="blue" class="small">( Converting some implements and tractors over to JD??? Need Decals too???
Egon )</font>
Why sad faces above? Don't tell us, Egon, you are a JD hater.
As to your questions; one of your citizens in Canada wanted me to send him an implement painted in JD green. I'm not a painter at JD corporate nor a JD fanatic knowing RAL# of that green. Help your citizen, Egon.
ok, I think it is either #6017 on this color deck attached
or, #6018 here on this deck attached.
Or, another one? What do you think
   / Color code of JD implements? #6
Nomad,
Maybe you should post this question in the JD forum?
Or maybe you have? I don't have enough time in the day anymore to read all the forms since I'm retired... /forums/images/graemlins/smile.gif so I don't know if you did or not...
   / Color code of JD implements? #7
Nomad,
Here's a roundabout semi-non-answer to your question.
Are you sure they are different shades? My guess is the prep and finish on the tractors is a LOT more involved than the implements. Even using the same paint, you would get a different finish over an implement that is just welded, washed and shot with paint. If you don't believe me, take a can of your favorite auto's touch up paint, a piece of iron and spray it once or twice. Then hold it up to your car to match--they won't.
The other item that might be of interest is that in the early 70s, US Mfgrs moved from lead based to non-lead based paints. At that time, at least some of them changed their shades of colors a little for price/availability of colors issues. So if you are trying to match or looking at an old implement vs a new tractor, they probably won't match based on paint makeup.
Hope this helps.
Ron (closet JD lover /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif)
   / Color code of JD implements? #8
Perhaps That is just what I am doing Nomad. Hate to see him stuck with a paint job.
Egon
   / Color code of JD implements? #9
Nomad,
I can't give you a direct answer other than to relate my experience. Maybe it will be helpful.
I had my JD yellow mower deck sand blasted and repainted. The paint shop found JD yellow listed in their "book" and said no problem. When I picked up the mower deck I noticed right away the color was wrong. It seems that the almost orange looking color of the JD construction equipment is aslo called JD yellow. The paint supplier could not find another JD yellow listing. I was told that JD, as well as other manufacturer's, may not always share their paint color formula.
My solution: I had a can of JD yellow for agriculture and residential equipment. I went to the paint supplier and sprayed up one of their color test cards, basically a 6x6 white card with a black checkerboard pattern. You repeatedly spray light coats until you can no longer see the black checkerboard pattern in bright sunlight. The paint guy then "read" the color with a contraption and duplicated the color. The color looked great but there was a slight difference between small pieces I painted from the JD spray can and the deck. But the deck was sprayed with a urethane paint over an epoxy primer so I would expect some difference. There was also a difference between the original yellow on the piece (weathered) and the JD spray can.
The can of JD green I have says "Intended for the following equipment: agricultural, commercial and consumer equipment" So I'm not sure if the tractor green is different from the implement green. Any differences you see between tractor and implement may be due more to normal variations in paint batches, weathering, or material differences.
Jeff
   / Color code of JD implements? #10
Hi Nomad,
you have run into the problem that has plagued man since he started painting stuff - color matching. Getting colors to match is why Henry Ford painted the Model T any color you want - as long as it's black. Color matching is one of the biggest problems that auto body repair shops have. This has gotten easier in recent years however because there are sophisticated systems out there that "read" the color of something and will duplicate that color when the paint is mixed. Auto body paint supply stores and auto body shops sometimes have this equipment and better paint stores that supply paint for house painting also have this now too. Like other posters have pointed out the same paint on different surfaces will have a slightly different color. I worked for a number of years in the auto body industry and can say that getting colors to match exactly is very hard. I would bet that John Deere does not spend any time trying to color match their implements to their tractors or vice versa. Unless you are taking the tractor on the show tractor circuit your best bet is just to find a color that matches pretty closely and leave it at that.
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
Steel Dump Hoist (A57454)
Steel Dump Hoist...
INOP Yamaha Timberwolf Four Wheeler (A57453)
INOP Yamaha...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
JCB Loadall 506B Telehandler (A57453)
JCB Loadall 506B...
