Complete newbie What Kubota for 3.1 acres
   / Complete newbie What Kubota for 3.1 acres #21
I have a BX 24 and love that I bought a machine with a BACKHOE!!!
I wouldn't want one without it.
   / Complete newbie What Kubota for 3.1 acres #22
1. Kind of a small piece, what's the split?
2. If you are set on mowing it get rid of the trees and smooth it out.
3. Any tractor will weigh more, if you add a decent BH a lot more.
4, Dig some of those trees out, spread the dirt around and level it out.
5. Again - another vote for a BH.
It really sounds like you need a small BX w/BH. This spring I passed on a few BX23's, 24's before I got my present ride. They were just way to small for me.
1**Check out Barlows - Used Kubota Tractors used.
Right now he's got 3 TLB's that fit your needs. He's well respected and shipping may not be that much.
Also - one of the advantages of a backhoe is the SHEAR FUN.
And make sure you get a thumb!
*I second that thought
   / Complete newbie What Kubota for 3.1 acres #23
*And Mr. Brown would never be biased.
As has been said many times and I agree. Either machine can do the job. But if your primary purpose is to mow lawns then get a BX. If your primary purpose is everything else I think you are better off with a B. The 3 Speed Transfer case alone is worth it.
*Who me ! :eek:
   / Complete newbie What Kubota for 3.1 acres #24
Well, I hate to be in the minority, but I have no need for a backhoe, at least not enough to spend the money for it and bother of putting it on and taking it off. My brother and I have a full size backhoe at our other farm and I haven't used it in years. If you need one fine, but don't spend the money on something someone else thinks you "need". Just an opinion.
   / Complete newbie What Kubota for 3.1 acres #25
i use a b7800 on 8 acres. for 3 acres a bx would be good esp. if you're just mowing the lawn.
   / Complete newbie What Kubota for 3.1 acres #26
I own about the same acreage, which I would agree is not the determining factor for tractor model. I mostly mow, but do some snow removal and plan to do more land improvements in the next couple of years. My first tractor was a BX2350, but despite liking the machine a lot, some of its issues (jerky trans, etc.) were enough to get me to trade. I thought I'd get the BX2660, but ended up with a B2620. The BX cuts the grass better, but the B does it quite well too and I like the slightly bigger machine. Either one will do the job, but for me it was a matter of preference. Anything bigger than a B on my property would be cumbersome, although I suppose one could justify anything to themselves (which I've done quite enough of!).
   / Complete newbie What Kubota for 3.1 acres #27
I think a lot of us are guilty of that.
   / Complete newbie What Kubota for 3.1 acres #28
Lest we accept that anything is "too big", I have been known to mow my two acre yard with my Case CX80 cabbed tractor with 8' finish mower when I had it up here doing something else around my property; seemed to be a shame to climb down out of the AC and fire up my Kubota.;)
   / Complete newbie What Kubota for 3.1 acres #29
Backhoes are like washing machines....
Once you have one, it's just really hard to live without.
Wow, Thanks for all the replies.
I have lots of brush that would really destroy my Zero turn mower and I'd feel better with just using a blade or a backhoe to get it up and dump in the eroded areas along my creek. I want the bush hog for the front pasture-like land because of the type of plants that grow there and I could get up against the creek edge and back the bush hog up the edge where I cannot do that on my zero turn.
I chose Kubota due to what I've heard about their reliability. I am considering a John Deere also due to their quick attach implements, and reputation.
I don't have the need for much ground clearance and am looking at the smaller units because I want one small enough to cross my bridge. My 52 inch zero turn weighs in at aroudn 600 lbs with gasoline and my 290 makes it a half ton. I figure a bx1x50 or bx2200 would be perfect.
   / Complete newbie What Kubota for 3.1 acres #31
I'm not sure what weight you have in mind that your bridge will support, but be aware that a BX25 weighs about 3000 pounds with a driver on it.
   / Complete newbie What Kubota for 3.1 acres #32
For what it's worth, I have a John Deere 2305 as well as my BX2660 and I much prefer the Kubota. Look at the deck and the blade belt, Kubota is twice as thick as the John Deere. The deck also raises up higher for much better ground clearance. The brake is on the left on the JD and the forward reverse pedal on the JD are side by side. My father in law hit the wrong one and ran his into a very deep pond. I also find the "joy stick" to be not as substantial and don't like the blade engagement on the JD.
I do like the steering linkage better on the JD as it is behind the axle and it has better ground clearance than the Kubota BX Series, but I haven't really needed it so far. It is an 08 model, so I can't say much about long term reliability. I did have my BX2200 for over five years without any problems and the new owner hasn't either and we both used it hard.
Not knocking the JD mind you, I just prefer the BX for my use.
   / Complete newbie What Kubota for 3.1 acres #33
<snip>I'd feel better with just using a blade or a backhoe to get it up and dump in the eroded areas along my creek.
Go for a blade - a BH is really way to much for that..
<snip>
Your looking at a lot more weight w/ a BX or any SCUT.
   / Complete newbie What Kubota for 3.1 acres #34
Two years ago we moved to 3.1 heavily wooded acres with a small creek. I bought a zero turn which works great for the 2/3 acre of fenced yard of st. augustine grass, but the front acreage is full of many many trees and lots of brush around the creek. I have a small well built bridge that handle my 600 lb. zero turn 52 inch lawnmower. The Zero turn is getting beat up by the front acreage as it is more pasture than anything else. Bumpy and tough to cut.
I need a bush hog for cutting the tough stuff and brush, and an FEL to move dirt rocks etc. to help work on erosion around the creek.
I was thinking the BX1750/2350 size. What do y'all think?
What this 'all thinks is that the decision on brand name has been premature.
   / Complete newbie What Kubota for 3.1 acres #37
Why do you have 2 tractors of the same size and type?
Why do you have to ask this question LB? We already notice you enough with that unnecessary smiley face.
   / Complete newbie What Kubota for 3.1 acres #38
I have a BX 24 and find it a very capable machine. The only complaint I can think of is FEL lifting capacity and lack of things such as FEL forks and what not. Also without loaded tires I find that the tractor runs out of traction when doing some work with the 3pt. Also implements for the 3pt finding used cat 1 and cat 2 equipment that works with the BX is tough in my neck of the woods. I have a woods 5ft grading blade that is too much for the tractor....... My suggestion / recommendation is go with a B unless you have really tight spots to get into.
   / Complete newbie What Kubota for 3.1 acres #39
I have two primary locations which I need these types of tractors. On the one where I keep the John Deere, my son and grandson also use it and they also use a JD 425, so I didn't want another JD in a pond when someone got confused. I also got the JD before I sold my BX2200 and kind of wanted to check the JD out anyway. Using the JD convinced me that I really preferred the Kubota, so I then bought the BX2660. Since my wife retired and started using my BX2660 so much, I may have to buy another one; wonder how a New Holland would do...
   / Complete newbie What Kubota for 3.1 acres #40
Unless you know you will need a BH, I'd save the $$$ you can always add it later... In 2 years I have needed one twice and got away with the bucket for the first job and rented for the second job...
Thats alot of implement to be leaving on all the time , or sucking up storage space unless you know you'll be using it....
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
2014 VOLVO A40G OFF ROAD DUMP TRUCK (A60429)
2014 VOLVO A40G...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A60429)
2016 CATERPILLAR...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A59905)
2017 INTERNATIONAL...
2014 Dodge Journey SUV (A59231)
2014 Dodge Journey...
