Concrete Footing PSI
/ Concrete Footing PSI #1
Pettrix
Platinum Member
High Desert Southwest
I've used 4,500 psi concrete footing mix on my previous home I built and it worked great. I talked with some contractors who only use 2,500 psi concrete footing mix and years later, wall cracks happen.
4,500 psi mix per yard = $130 yard
2,500 psi mix per yard = $110 yard
Let's say 30 yards were used for the footings. That's only a $600 savings and could make the difference between a solid home vs issues with movement/cracking.
I don't get it but that's how some contractors save money but going back trying to fix a failing footing will cost thousands of dollars.
/ Concrete Footing PSI #2
Pettrix,
check codes first. But The point of a footer is to spread out the load. So increasing the width is also a big driver. Use well placed rebar on chairs with minimum overlaps. And make sure concrete is not poured on lose/soft soil. A poured wall will act like a beam vs. CMU wall, and can span weak spot soil conditions.
In the rainy midwest, there is always risk of water filled trenches between digging and pouring. Try your best to having the footers dug and poured with out rain.
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
iDrive TDS-2010H...
