Coolant leak question TC33D
   / Coolant leak question TC33D #1
sherpa
Platinum Member
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
I have a coolant leak on my TC33D. I attached a picture so you can identify where the leak is. It is on the right side of the engine just to the right of my oil filter. I need to know if this plug has threads or is pressed into the engine block? It is in line with the freeze plugs. Can this plug be tighten or should I just use some stop leak?
Thanks,
sherpa
   / Coolant leak question TC33D #2
Based on its shape, hex, I'd guess it has threads. The picture at Messicks shows threads on it. $32.60.
   / Coolant leak question TC33D #3
It is a common problem. The hose connector is made from zinc and will react with iron. I replaced mine when the tractor was nearly new with brass and it has yet to leak after these years. Pictures will follow very soon.
   / Coolant leak question TC33D #4
Here is what it looks like and the tool to get it out with. I milled a slot into a heavy impact socket to get it out in one piece. You can just cut the bib part off and use a 1-1/16 deep 6 point socket too.
   / Coolant leak question TC33D #5
Where can you get the all brass version and what's it called? :)
   / Coolant leak question TC33D #6
Thanks so much for this info!
I will order my parts and get them here before I cut the barb off.
sherpa
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
PALLET TOTE OF MISC CABINETS (A58374)
PALLET TOTE OF...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
HELI 5K FORKLIFT (A58214)
HELI 5K FORKLIFT...
