Cub Cadet 7274 question (built by Mitsubishi).....
   / Cub Cadet 7274 question (built by Mitsubishi)..... #1
B52
southwestern NYS
Kubota B2620 ; also 1939 AC model B
I noticed my '96 Cub Cadet 7274 (this is a 4 wheel drive, manual transmission, 27hp 3 cylinder diesel built by Mitsubishi with 400 hours on it) has started having the right rear brake stick in the on position after I apply it. The brake pedal itself still has movement, but the brake pads seem to be stuck internally. This is the right side only, left brake works fine. I can release the right brake by tapping the brake rod (linkage) backwards with a small hammer (reaching under the side of the tractor).
I'm not exactly sure what Mitsu tractor is the equivalent to mine, but I thought someone might have some advice for a problem like this ?
Thanks in advance.
   / Cub Cadet 7274 question (built by Mitsubishi)..... #2
The 7274 has wet brakes.To get at them you have to remove the axle housing. There is a spring in ther that probably is either broke or unhooked.
Re: Cub Cadet 7274 question (built by Mitsubishi).
Thanks lens12. I'm not familiar with wet brakes. Are they like a disc brake submerged in oil ? Or are they just like regular brake shoes expanding outwards towards a drum and everything in oil ?
Also, do you sell repair manuals ? Would you have one for my model 7274 ?
Thanks again .........
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2018 Grove 700E 60T Crane (A60460)
2018 Grove 700E...
2019 FORD E350 16FT BOX TRUCK (A59575)
2019 FORD E350...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
