Cub Cadet LT1042 PTO issue?
   / Cub Cadet LT1042 PTO issue? #1
SUPERNUG
Bronze Member
MID MICHIGAN
BX22
When I finished mowing today there was a lot of vibration when I shut off the PTO. Looks like the belt is in rough shape and needs to be replaced so I ordered one. However it appears the PTO clutch pulled the wires and severed them at the plug. What would cause this? Is a new PTO needed?
   / Cub Cadet LT1042 PTO issue? #2
If you are REAL lucky (and a bit of a shadetree electrician) you may be able to reconnect those wires and insulate same well enuff to make do.
If you look under your tractor , there is a static plate - (part of the clutch assy) that bolts up to the frame and holds one part of the clutch assy static (the part carrying the wire harness). That part apparently came loose and caused your wiring problem.
That assy will have to be re-attached to the tractor. You will have to have the hardware to do it. The other thing to chk while under there is that the PTO pulley that normally drives the mower blades turns freely on it's own bearing with all power off. If it drags or turns hard, then the PTO assy must be repaired or replaced ($$$$Ouch!) Good Luck.
   / Cub Cadet LT1042 PTO issue? #3
a good solder job will fix wire prob's ,more than likely if you changed the belt and removed the belt guard that go's around the clutch might not be holding the clutch in place or you missed realigning it(part of the guard must be in the slot in the clutch to keep it from spinning)
Thanks for the replys rcbe and gladiater. You were right the belt guard was not in the slot on the clutch so the clutch portion holding the wiring harness turned freely. I was able to repair the wires and with the new belt it works great.
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2012 John Deere 6170R (A57148)
2012 John Deere...
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
John Deere 6300 (A60462)
John Deere 6300...
