Cutting fluid for drilling holes?
   / Cutting fluid for drilling holes? #1
blunosr
Northern BC, Canada
Kubota MX5000, Ford 5000, Massey Ferguson 1080, Bobcat A300
Hi, I'm re-mounting my FEL and am drilling lots of large holes in 1/2" plate. I have been using motor oil as cutting fluid, but it seems to me that real cutting fluid is some kind of soap?
I've used lots of cutting fluid on lathes, and metal band saws, but I just don't remember what it's really made of. I'm sure someone on here knows...
What do you guys use for cutting fluid?
Thanks,
   / Cutting fluid for drilling holes? #5
Thanks,
I use this stuff
Oatey Dark cutting fluid
Dark Thread Cutting Oil :: Oatey.com
   / Cutting fluid for drilling holes? #7
In a pinch, you can use all sorts of things -- I have regularly grabbed kerosene, alcohol, or WD-40 with good results. I am sure diesel would do as well.
Here's an article with more detail than I could hope to explain:
Cutting fluid - Wikipedia, the free encyclopedia
   / Cutting fluid for drilling holes? #8
Cool tool works well for cutting and tapping it's a bit expensive.
   / Cutting fluid for drilling holes? #9
A machinist told me that you can use water, he said all you are wanting to do is cool the drill bit. Myself I have used WD40, but that gets expensive.
   / Cutting fluid for drilling holes? #10
You want to cool the tool but you also want to lubricate,and keep chips clear to disperse the heat.
   / Cutting fluid for drilling holes? #11
x 2.......:thumbsup:
My machines (lathes and mill) use water-soluable oil.......95% water, 5% oil......
the oil is just used to prevent the machines from rusting when idle.....
it will work totally fine if it was just 100% water.......keeping the drill cool constantly is the key......ya just can't cool it when it looks hot to you, you need to "Flood" it with water......just trickle it on the drill bit
I've used a garden hose with drill press outside to drill out 1.25" holes.....let the mess dry up afterwards or catch it in buckets
   / Cutting fluid for drilling holes? #12
Thank you for the info, I have burned up too many drill bits.
   / Cutting fluid for drilling holes? #14
   / Cutting fluid for drilling holes? #16
Thanks,
I have used Westlube for about 30 years with great results, :thumbsup:. Here is a link:
Westland Products Company
Good luck with your search, KC :D :D :D
   / Cutting fluid for drilling holes? #17
Crisco shortening works amazing - even better on aluminum. Obviously can't spray it on as you go, but you can coat a bit or blade ahead of time and periodically. Also, with a large syringe, you can squirt some as you go.
You've got to try it - you'll be amazed. I learned this from a man who owned a global company which did tele-robotic welding, so it was an expert source!!
   / Cutting fluid for drilling holes? #19
The stuff we use at work is pretty good, I just cant think of the name of it.:confused2:
It comes in an aerosol can, and when sprayed it looks really foamy. But it is extremely sticky and tacky
   / Cutting fluid for drilling holes? #20
+1 for WestLube more of a paste than oil
Hardest drilling I did was drilling out broken exhaust studs in a 460 ford motorhome engine. Worked great and made it possible
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
208320 (A58375)
208320 (A58375)
set of 4 tractor trailer tires Roadforce (A61306)
set of 4 tractor...
John Deere 5105M (A53317)
John Deere 5105M...
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
(4) MONTREAL RADIAL S/T 205R75R15 TIRES (A60430)
(4) MONTREAL...
