Deere 3038e won't start, just a click, but not the good click.
   / Deere 3038e won't start, just a click, but not the good click.
Try running a jumper between the two leads on your neutral safety switch. It should be a shielded loom on the left side under the floorboards that goes to a sensor on the transmission. On the schematic it is #22. Part # RE12363
My 4310 had similar issues and I just pulled the two wires out of the loom and then pierce the insulation with a test light and jumped it with a paperclip just to see if it would work and it solved my issue but mine is power reverser. The sensor on mine is really buried under the floorboards to the point where I could barely see it.
awesome man I've been looking for that! I found the sensor, pulled it and jumped it and unfortunately no change...
pull that red cover back, there's more than one wire in there, try jumping the small red wire to the battery + and see if it cranks.. it could be that the black wire needs to be grounded though, depending on the safety switch arrangement..
ok so I pulled the red cover and the big wire (that comes straight from the battery along with the red and the discolored black wire all attach to the same terminal. I went ahead and did what you said and ran a jumper from the positive terminal on the battery to this terminal but it didn't do anything.
   / Deere 3038e won't start, just a click, but not the good click. #13
Does your tractor dash typically have more lights blink on startup besides only the oil light? Typically all the lights will do a self test. Couple other things to look for is to check the ground wire on the battery where it bonds to the frame. Sometimes corrosion will make a poor ground and the accessories will work but won't be able to draw the amperage to crank the starter.
It might be time to start running a test light or a voltmeter with the key in the run position and making sure you are getting voltage at all your safety switches such as the seat, PTO, etc.
If all those test out then move to the starter solenoid, When you hold the key in the start position the wire should show voltage. If it doesn't then it is most likely your ignition switch. If it does show voltage then it's either bad ground, bad battery or bad starter solenoid.
I am going to jump the gun here and say it's either a bad/corroded ignition switch or a bad ground. My Z-turn mower I have I had similar issues with no start no reason and it ended up being a similar style ignition switch.
I feel like there are more lights that come up but at this point I cannot be certain unless other 3038 owners can verify for me lol. I've tried watching YT videos of people with 3038s but no one shows the cluster while starting.
I don't have a test light or voltmeter so im going to have to rig something up for that and check what you mentioned.
   / Deere 3038e won't start, just a click, but not the good click. #15
Without a simple 12v test light or low grade multimeter you are swinging in the dark my friend. That kind of limits you to blind guessing on what the problem is. You really need these two items if you are going to troubleshoot circuitry.
I had to drive into town so I grabbed one while there. Will be testing tomorrow ��
   / Deere 3038e won't start, just a click, but not the good click. #17
View attachment 574206[/QUOTE]
you can start this manually by disconnecting the spade terminal connector on the bottom of the start and touch the spade terminal on the starter with a jumper wire to the hot terminal behind the red protective cover on the starter wires
   / Deere 3038e won't start, just a click, but not the good click. #18
I hate to ask this but do we even know if the battery is good?
   / Deere 3038e won't start, just a click, but not the good click. #19
then the black wire may be the problem. it may be running through a defective safety switch. try grounding that out to the chassis, and have someone try to start it then.. the solenoid needs both a ground and a hot to work.. just like a light bulb. 2 wires..
you can start this manually by disconnecting the spade terminal connector on the bottom of the start and touch the spade terminal on the starter with a jumper wire to the hot terminal behind the red protective cover on the starter wires[/QUOTE]
went out this morning and check the battery, it was at 12.08.. so I did what you suggested and jumped from the spade to the hot terminal and it cranks.
I assumed I could start the tractor this way but it wouldn't ever start. it just kept cranking. I tried turning the key at the same time and made sure all the safety switches were in the correct position. checked for fuel and there is fuel.
So I'm getting it to crank this way but now I'm lost even more lol.
metered the seat safety switch as well and it was open but when I turned the key i would get 12.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2013 Godwin CD103M Towable Diesel Pump (A59228)
2013 Godwin CD103M...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
golf cart (A56859)
golf cart (A56859)
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
