Deere load control leak
/ Deere load control leak #1
webcrum
Rio Linda Calif
John Deere 301A
Hi all I'm new here so be gentle, I have searched but haven't found a answer so I will just ask
I have a Deere 301A with a large leak from the load control shaft. I need to replace the o ring on both sides. Do I need to remove the bushings to get to the o ring? how is that done? Looks like it should be a easy replacement, any advice?
Thanks
Ed
/ Deere load control leak #2
I can't remember ever changing them in a 301, but I don't think it's any different. The o rings can be changed without removing the bushings, but there's a good chance the bushing are worn and it will just start back leaking. If they don't appear to be worn you can give it a try. I would also look at the shaft close, sometimes the o ring will cut a groove in the shaft.
The bushings are drove into the housing. To remove them, I use a long punch (coming in from the opposite side of the housing) to catch the edge of the bushing a drive it out.
/ Deere load control leak #3
Wear on bushings will be determined by how much use and difficult loads were exerted on 3 pt. I think side to side movement of the shaft causes more seals to leak than worn bushings so be sure to shim draft arm to shaft snug.
/ Deere load control leak #4
Your right about the side to side motion ruining the seals,digging about 100 post holes is what started my 2040 to leaking real bad.Shelly rock would just sling the post hole digger from side to side as it went through the rock.
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2020 John Deere 8R280 (A64119)
2020 John Deere...
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
