Delo 400
   / Delo 400 #21
The synthetic Rotella T 5W-40 would be fine for 100 hour change outs on the L-39.
BTW, metallo-sulfated ash is a result of the additive package and it ends up building up on piston crown combustion chamber, rings, valves, etc. The lower the ash the better in the long run.
The Group III Shell Rotella is not the best available, but it certainly is fine for a non-turbocharged three cylinder IDI diesel as long as you change it and the filter out every 100 hrs.....
   / Delo 400 #22
</font><font color="blue" class="small">( If it's API rated CI-4, it's "plenty good enough" oil for your Kubota, regardless of whether it's synthetic or dino.
)</font>
And why would a tractror need CI rated oil? This rating is for emissions.
   / Delo 400 #23
I agree with Skypup. Rotella or most any 5w-40 diesel rated oil will be just fine for your tractor. We have several tractors and changing according to mfg. recommendations noticed no difference in all with wear patterns. Our newer tractors go 250 and 400 hours in between oil changes. We don't even use synthetic anymore but just regular Rotella. The oil at changes is still showing fine but the problem with tractors is keeping the oil clean. Even with the best filters if you are working your tractor in dusty, dirty conditions your oil is going to get dirty.
   / Delo 400 #24
</font><font color="blue" class="small">( We have several tractors and changing according to mfg. recommendations noticed no difference in all with wear patterns. )</font>
Can you support this claim?
   / Delo 400 #25
<font color="blue"> Can you support this claim? </font>
As you know, we've been down this road before. All the documentation is hardcopy. Either you, or others, believe what doc is saying or you don't. Others also post numbers from their oil analysis, no one asks for a scan of the hardcopy results. Even then, we'd be trusting that the information is really from oil W, run through engine X, for Y hours or Z miles.
   / Delo 400 #26
And why would a tractror need CI rated oil? This rating is for emissions. )</font>
It doesn't need CI-4 oil. But that is what is available on the shelves and CI-4 is backwards compatible to all but those oils rated for 2-cycle diesels. Aren't the synthetics you recommend CI-4?
   / Delo 400
So the only Rotella I could find is 10W-30. Does anybody see a problem with 30 weight? I figure I'll put the next hundred hours on before January.
   / Delo 400 #28
</font><font color="blue" class="small">( <font color="blue"> Can you support this claim? </font>
As you know, we've been down this road before. All the documentation is hardcopy. Either you, or others, believe what doc is saying or you don't. Others also post numbers from their oil analysis, no one asks for a scan of the hardcopy results. Even then, we'd be trusting that the information is really from oil W, run through engine X, for Y hours or Z miles. )</font>
Without seeing the oil tests, I do not buy it. And yes I have been down this road before since the reason for not doing it is pretty bad.
I have asked repeatedly for this (along with another user) and someone can take a few minutes and post the numbers; to support his claim.
The "documentation is hardcopy" is a pretty poor reason not to take 5 minutes and post it.
I think you where the one that posted several times to show proof on a subject I made on a thread; and I am doing the same thing here. Just show the data to support your claim. Without anything to back it up, it is meaningless.
Per TBN rule #3, you would think a user would want to support his material.
   / Delo 400 #29
</font><font color="blue" class="small">( It doesn't need CI-4 oil. But that is what is available on the shelves and CI-4 is backwards compatible to all but those oils rated for 2-cycle diesels. Aren't the synthetics you recommend CI-4? )</font>
Correct they are but I do not put much faith in them either nor promote it either. I would rather go for oils that conform to ILSAC, ACEA, MB, Volvo etc. These are harder spec to pass.
   / Delo 400 #30
<font color="blue"> Without seeing the oil tests, I do not buy it. </font>
I tend to trust people. Afterall, why would they come on here and lie?
<font color="blue">I think you where the one that posted several times to show proof on a subject I made on a thread;</font>
I don't recall doing this, but if you say I did, then I did. Sorry.
<font color="blue"> Per TBN rule #3, you would think a user would want to support his material. </font>
Forum Rule 3. No advertising in the forums.
No one is advertising here.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A54757)
UNUSED LANDHERO...
