Re: Diesel fuel in plastic \"gas\" cans
dhech1961, The reason for different colored fuel cans is purley a safety issue and to keep people from mixing two different fuels together. Red is always for gas because it is more flamable then diesel or kero. It also lets the guys in the fire dept. to quickly identify what is in someones car/truck if there is an accident, Hense you do not want a combustable liquid laying on the ground while you are taking care of a patient in a car accident. Remember gas as a liquid does not burn, it is the vapor that burns, while deisel and kero burn as a liquid. Also the colors are suspose to keep people from putting gas in kero. heaters. I've seen it happen and the end result of such a mistake.(A loss of someones house) As for the bleed of two different types of fuel in plastic cans is true,but it is so minimal that you or the piece of equipment could not detect it. As an example if you use an old clorox bottle an make a funnel out of it, no matter many times it is used or washed it always smells like clorox. It does not hurt anything but it still smells. I hope this helps. John
