Dipper Stick snapped in half
   / Dipper Stick snapped in half #71
Eddie, i think you made the right call.
With it off the machine they can jig it, pull it etc make shure its square/straight.
its easy to move heavy stuff like that if the shop is setup to handle it. overhead grantry cranes, forklifts, 800lb lifting magnets, straps etc.
   / Dipper Stick snapped in half #72
If Eddie could dig a hole with his dipperstick broken almost in two, fixing it wouldn't be such a priority, don't you think?
Kudos to Eddie, you got it off and delivered to a shop you have confidence in, so they can do the job the way they want to. This repair can't help but be a success.
:laughing::laughing::laughing: Did you honestly think I was meaning dig a hole with that backhoe? Eddie has more than one machine that can dig in a pinch.:D
hugs, Brandi
I took off the bucket and then moved the boom over and rested the end of the dipper on the dirt. Then I built a stand to support the weight of the Dipper and plugged the hydraulic lines. After it was all disconnected, I had my dad lift it and put it in the back of my truck.
Eddie
   / Dipper Stick snapped in half #76
Holy cr@p!! Look out Eddie!!!! Your dad's driving your tractor again!!!
   / Dipper Stick snapped in half #77
Thats one way to hold the osb down in the bed of the truck. There are much easier ways though for the future Eddie :laughing:
I'm glad it came off fairly easy for you and hopefully it will be fixed and back together quickly.
   / Dipper Stick snapped in half #78
FWIW, I would have strapped that down quite differently in the bed of the truck.
With any heavy object the real issue is not preventing it from sliding backwards, it is preventing a forward slide.
The brakes are ~3 times as strong as the engine, and there are situations when you have very little control over how hard to apply the brakes. There is never a situation where you must accelerate hard.
   / Dipper Stick snapped in half #79
Good (and quick) job, Eddie. You'll be back to diggin' in the mud again soon. I couldn't help but look at the muddy tires as your dad loaded the dipper and be a bit jealous. It's been a long time since we've had enough rain to cause mud like that. :)
   / Dipper Stick snapped in half #80
I saw that to Jim and thought, mud in Texas, now I know Eddie made up the whole story. :laughing:
MarkV
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2024 JOHN DEERE 250P EXCAVATOR (A60429)
2024 JOHN DEERE...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
