discing
   / discing #11
More weight and crossing pattern will help.
Looking at the disc pics, I think the disc blades may be worn a good bit judging by the clearance from the frame to the blades. That might affect how aggressively it cuts.
If you could use a chisel plow, then disc, it would help.
Dave.
   / discing #12
First time using a disc today.
Pics are of one pass over the ground. It is recently cleared and I am looking to make it into pasture.
It does not dig in deep enough. More passes at an angle and more weight on the disc? How much weight would be in the ballpark?
Warhammer
Your disc looks a lot like an old 6-ft Ferguson disc a bought a few years ago.
I use a 6.5 ft Towner offset disc for primary tillage. It's a heavy dude-600-700 lb. I add about 480 lb of weight (four 120 lb concrete weights) to that disc to get it to bite. You need to pull discs at 4-6 mph to get them to work properly.
   / discing
I have added 300 pounds to the disc and made 2 more passes in a crossing pattern on one area. It definitely works better and has cut in 3-4 inches.
Dave.
   / discing #14
You are making progress. That must be some well packed, hard soil. I wonder if it might be a good idea to go over it with a sub-soiler. How deep do you need to get for a good pasture seed bed?
Dave.
   / discing #15
For grasses, I would think you've tore it up enough. Good job.
For potatoes and other gardening plants that need a 6-8" bed, that job would be a whole lot quicker by breaking it first with a inexpensive middle buster type tool. That is why those MBs are so darn popular with guys here at TBN.
For what you are gonna do, what you have there will be fine, I should think.
   / discing
How close together do you run rows with a middle buster?
To break the clods up and smooth things out would dragging a chain harrow work? I want to put grass seed out next month and there is not enough time for the weather to break down the clods.
Since I plan on broadcast seeding I am thinking I need to smooth the dirt out, run my landscape rake over it to make small furrows, broadcast the seed and then drag it to cover the seed and compact it a bit. I am trying to establish common bermuda.
   / discing #17
Dragging a chain harrow may just bring all the clods to the surface.. If the clods aren't dried out and hard as a rock, a roller or drag board will work...
   / discing #18
I can only describe what works for me. With a middle buster plow, your front wheel will always follow the old furrow. This will make sense when you are doing it. Plow, follow it with another plowed furrow, and continue on until your field has been gone over once.
This will create "hills and valleys" at a spacing that is half as wide as your tractors wheels are set apart. On my second time working the field, I then stagger. This way i am plowing the hills, where the plow had not dug down on the previous working of the field.
Two words to all plow boys. Fall plowing. This enables the natural temperature swings to break down the clods. The frost/thaw cycles are your friends.
   / discing #19
I agree... plowing first or at least using an offset disc first will make the process faster. I'm in the same situation, but I plowed first, disced the second pass, and plan to disc again as soon as it dries up a bit. I plan to put out potash prior to the next discing. Use the disc you have pictured for the 2nd and third pass to help level and breakup the clods.
   / discing #20
Decreasing the angle should help it cut deeper also. Then, once you got it cut down, you can adjust the angles back up to get it to "kick" the dirt farther and loosen up the soil better...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
UNUSED FUTURE FR70 HYD FLAT RIPPER (A57193)
UNUSED FUTURE FR70...
BOX OF (2) GENUINE MOPAR SIDE STEPS (A57192)
BOX OF (2) GENUINE...
UNUSED FUTURE FT15 EXCAVATOR (A57192)
UNUSED FUTURE FT15...
