Disk harrow question
/ Disk harrow question #1
artp
Bronze Member
Southern Illinois
Kioti CK30HST
I am considering using a tandem disk harrow with my new Kioti CK30HST to get about an acre of rough meadow sod broken down. I had previously run through the meadow with my rippers on a 5ft box blade to open up the ground. I then tried to used Dad's old Ford tiller to work the ground, but it was too light weight and did not seem to break up the clumps of sod. So I am wondering what size/weight disk harrow would work best with my size tractor. Suggestions?
/ Disk harrow question #2
I pull a 5' disk behind my L2800 so your CK30 should be able to handle a 6' without any problem since your a little heavier.
As an alternative to the disk/harrow I am considering a 5ft tiller. I have seen several different brand names on TBN. Which ones have had good track records with owners here on TBN? Is chain driven or gear driven better? Reliability? Offset feature a good idea or just an additional cost item? The pasture area I am working on is open ground-only about an acre. I may be putting in a small garden in the future-wife wants home grown veggies. Your advice appreciated.
/ Disk harrow question #5
The KingKutter & CCM has good reviews.
I have a 45" Agric gear driven I pull with my 15hp Mitsubishi tractor, it works just fine.
Thanks for the feedback guys. I am getting prices for CCM & KK.
/ Disk harrow question #7
I have a 60inch KKII behind my Kioti CK53 Gear without any problems breaking new ground. That said....When the slip clutch gets hot.....you are DONE until it cools. I have TONS of rocks and the tiller finds them fast. I have to keep one hand on the 3pt lift at all times.
APPROX (23) 3'X8-10' HEAVY DUTY INSULATED PANELS (A62131)
APPROX (23)...
8087 (A61165)
8087 (A61165)
2019 International LT625 Sleeper 48" (A62613)
2019 International...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2022 Kuhn FC4461 TCD MoCo (A63116)
2022 Kuhn FC4461...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
