Disk harrow question
/ Disk harrow question #1
artp
Southern Illinois
Kioti CK30HST
I am considering using a tandem disk harrow with my new Kioti CK30HST to get about an acre of rough meadow sod broken down. I had previously run through the meadow with my rippers on a 5ft box blade to open up the ground. I then tried to used Dad's old Ford tiller to work the ground, but it was too light weight and did not seem to break up the clumps of sod. So I am wondering what size/weight disk harrow would work best with my size tractor. Suggestions?
/ Disk harrow question #2
I pull a 5' disk behind my L2800 so your CK30 should be able to handle a 6' without any problem since your a little heavier.
As an alternative to the disk/harrow I am considering a 5ft tiller. I have seen several different brand names on TBN. Which ones have had good track records with owners here on TBN? Is chain driven or gear driven better? Reliability? Offset feature a good idea or just an additional cost item? The pasture area I am working on is open ground-only about an acre. I may be putting in a small garden in the future-wife wants home grown veggies. Your advice appreciated.
/ Disk harrow question #5
The KingKutter & CCM has good reviews.
I have a 45" Agric gear driven I pull with my 15hp Mitsubishi tractor, it works just fine.
Thanks for the feedback guys. I am getting prices for CCM & KK.
/ Disk harrow question #7
I have a 60inch KKII behind my Kioti CK53 Gear without any problems breaking new ground. That said....When the slip clutch gets hot.....you are DONE until it cools. I have TONS of rocks and the tiller finds them fast. I have to keep one hand on the 3pt lift at all times.
WACKER NEUSON LTN6L LIGHT PLANT/ GENERATOR (A65056)
WACKER NEUSON...
20125 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
20125 WINSTON...
300 Gal Poly Tank & Cradle (A64912)
300 Gal Poly Tank...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
