DIY Digging trenches for Geothermal
   / DIY Digging trenches for Geothermal #71
Yea, that's another gripe I have with hvac contractors in this area....they like to undersize the units. And rely on backup heat in the winter. It kinda defeats the purpose of installing Geo and going "green" and all. Then claim it has to do with dehumidifying the house, and if the ac doesn't run long enough it won't dehumidify and it won't "feel" as comfortable.
Don't buy into that bs either.
Wanting to keep a home 70 when it is 95 outside....that's a 25 degree temp change.
Wanting to keep it 70 when it's 20 outside is a 50 degree Delta. Takes twice as many btus.
So a unit sized for ac....quickly becomes too small once temps drop below 40 in my area.
2-stage helps solve this issue too.
They are actually right on the dehumidification issue. Geo is designed using BIN data for your area. Their arguement is why pay for another ton on the unit if your only expected to run in that range for a few hrs in an avarage yr. Two stage does help the issue.
We had to deal with a lot of rain on Saturday and Sunday a couple morning showers. But after lunch we were able to dig. One 270 trench 3 wide 6 foot deep is done.
I have started digging from the house to the fence 4' wide 5'-6' deep.
I sure wish I had bought a 16" bucket but I am getting it done with the 10" bucket.
I guy that is digging has a day job digging for someone else so he will come after work to finish.
   / DIY Digging trenches for Geothermal #73
Try to get some good topsoil in direct contact around the geopipe. Clay is not good.
Clay is what we have here the top soil is very thin here just a couple inches. That is why we put in extra loop in because of the clay soil.
I am putting in 800' pre ton.
   / DIY Digging trenches for Geothermal #75
Yeah, but... but... your dirt is RED! :eek:
Yes, I know, "in the south"... but it still gets me every time I see that! :laughing: First time was when I visited my brother at Redstone Arsenal, in Huntsville, in 1966. Had never seen red dirt before. :confused2:
I grew up in PA about 1-hour north of Pittsburgh. We had top soil more than a foot deep and then the dirt looked like dirt.
It grew plants.
It took a while to get use to the red dirt here. It stains everything it touches.
   / DIY Digging trenches for Geothermal #77
That should be good, i have 500' per slinky per ton, plus another 100' each way out to the slinky, so 700 total. I put a layer of topsoil over mine, then filled.
   / DIY Digging trenches for Geothermal #78
I used 800' per ton too.
Couple of reasons....800' was the longest continuous roll I could source locally, and because 4 loops of 800' each was only $200 more than 4 loops @ 600' each. (~$800 vs ~$1000)
The way I did my loops....I dug ONE trench ~ 80' straight out from the basement. Then perpendicular to that was the 4 trenches all coming off that main, each trench ~120' long. Each spaced ~20' apart....
So trench 1 actually has the most "slinky" to it. Since its only 20' out....20' back in the main part of the trench....so that one has ~760' slinky
Trench 4....being 80' away.....would have 160' NOT in slinky mode.
But all that is irrelevant....at the end of the day there is 4x800' of pipe in the ground doin' its thing.
This is my thread with pics of my plumbing/loops
https://www.tractorbynet.com/forums...geothermal-plumbing.html?highlight=geothermal
Thanks for the link there was some very good reading there.
2018 Ford Fusion (A56859)
2018 Ford Fusion...
2017 Ford F-450 Service Truck w/ Liftgate (A56858)
2017 Ford F-450...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
19015 (A55788)
19015 (A55788)
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
